D-19 OEM Overhaul Kit
Roger Chlian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Chlian Quote  Post ReplyReply Direct Link To This Post Topic: D-19 OEM Overhaul Kit
    Posted: 13 Dec 2022 at 4:26pm
For Sale: OEM sleeves-pistons for D-19. Tag on box says Deutz-Allis #74062376 4.
For more information call RC at 320-760-6882.
Edited by Roger Chlian - 15 Dec 2022 at 10:36am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2022 at 9:01am
So, are they gasoline??   diesel ?? or LPG ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Chlian Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2022 at 11:02am
In original boxes and the Deutz Allis # is: 74062376 4
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2022 at 8:06am
You haven't answered Dr's question! Gas, Diesel, or LP?
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2022 at 8:17am
Pretty sure he has no idea.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2022 at 10:23pm
I can't verify what they are either with that part number. If they have a power crater bowl, they are gas or maybe LP gas. Flat tops are diesel even if they have one small valve relief cut in them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Chlian Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2022 at 11:23am
Pistons do have a cut out.  We are not able to get the picture posted due to size limitations?  If I had your phone number I could send the picture via text message. my number 320-760-6882. Thank you. RC
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2022 at 10:50am
Roger send you a text
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2022 at 11:08am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2022 at 12:18pm
They are gasoline or LPG. Probably gas, as they didn't make many LP tractors.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2022 at 1:07pm
  That dish looks pretty deep to be gas????
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2022 at 3:38pm
Look like the ones I pulled from my gas 262
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2022 at 7:04pm
The only difference between gasoline and LPgas pistons is the piston pin hole location changing the compression ratio from 8.0 to 1 up to 9.35 to 1.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2022 at 4:48pm
Service manual for D19 states center of pin bore to top of piston is 1.927 to 1.9345 for gas and 2.081 to 2.0885 for LP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Chlian Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2022 at 9:22pm
Kit is for a gas. Thank you to all of you who helped identify this overhaul kit.  I appreciated the help. Merry Christmas!
This page was generated in 0.754 seconds.
