B10 pulley question
Huckleberry8961 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Huckleberry8961 Quote  Post ReplyReply Direct Link To This Post Topic: B10 pulley question
    Posted: 18 Dec 2022 at 2:05pm
I recently bought a B10 that came with the mower deck and the snow blower attachment. Unfortunately it didn't come with the belts for either and I'm also missing the front pulley that mounts to the gear box on the motor and one of the small pulleys on the snowblower. Could someone help and tell me the sizes I need for the front pulley and belts? Also if someone has a picture of how the pulleys and belt run for the snow blower that would be appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2022 at 2:35pm
Could you post pictures of what you have
Post Options Post Options   Thanks (0) Thanks(0)   Quote Huckleberry8961 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2022 at 4:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Huckleberry8961 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2022 at 4:12pm
From what I can tell the pulley on the blower that I'm missing is the idler pulley. Hopefully sometime this week after work I can get it cleaned off and drug into the garage
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2022 at 5:45pm
I believe there are 2 idler pulleys just in front of the axle.
The 2 pulleys change the path of the belt by 90'.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2022 at 5:52pm
Something is not right with engine. It shouldn’t be sticking that far through grill. It sits behind grill with just tip of crank shaft sticking through
Post Options Post Options   Thanks (0) Thanks(0)   Quote Huckleberry8961 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2022 at 6:23pm
It's a Briggs and Stratton motor that's on it. The front grill assembly doesn't have any bolts truly holding it on and besides the gas tank and seat that's pretty much how I picked it up. Picked it up for $300 knowing it hadn't been ran in a few years but the motor still turned over. What the previous owners did or didn't do is hard to say.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Huckleberry8961 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2022 at 6:26pm
I believe you're right Gary and I should have specified that it's the right pulley as you're sitting on the tractor that is missing from the blower. Wish I had gotten it put into the garage before we got the 14" of snow this afternoon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2022 at 6:54pm
There’s another post named few pics of my collection with picture of b10 with snow thrower. You can see how it looks. That’s a newer blower then yours but same idea. Can see the grill and front pulley
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2022 at 7:10pm
I was thinking of my HB-112 when I spoke of the 2 idler pulleys.
I found now that the earlier B-10 has a different set-up, referred to here as the 3 belt system.
Zippos Video at time 2:30 he explains the 3 belt drive system.
G
Seems I forgot the Link. Sorry
https://www.youtube.com/watch?v=9tp0YvQ03Dw
G
Edited by Gary - 21 Dec 2022 at 7:39am
This page was generated in 0.172 seconds.
