Welding CAUTION
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Welding CAUTION
    Posted: 13 Dec 2022 at 8:57am
Friends of mine run body shops, also a few still in welding field and shop, come to find a few have been sued in recent history for Electronics Damage to cars, light and heavy trucks even heavy construction machines.
If need to do ANY welding AT ANY position on the current level of electronics machinery in our lives, 'MUST' completely Disconnect Batteries and absolutely Clean off Ground location COMPLETELY.  As much a Buddy of mine with a later Harley is suing a shop for electronics damages to his ride as they welded a small failure on the rear frame.  CANBUS will not forgive not disconnecting the electrical on these machines.  99% of all these electronic marvels on the streets and fields have some proprietary form of CAN BUS Technology in them including tractors, implements, combines etc.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2022 at 9:02am
Need to place your work lead, (ground clamp) as close as possible to your weld zone too. Keep the electron path as short as possible.
Edited by Codger - 13 Dec 2022 at 9:02am
That's All Folks!
knkrein1 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote knkrein1 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2022 at 9:49am
Well Dave I found that out the hard way when I was welding on my newer green tractor. The old AC's were not a problem.  When I got done welding the tractor would not start! Ended up having to buy a new solenoid. Wasn't hard to fix - just the idea. I have learned to remove the battery connection first.
Ken R.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2022 at 10:07am
I wrote this as have so many old friends some in some not in farming that have had or done damage.  Family of mine in IL welded on a newer(bought used) Red round baler, has electronic screen controller sits in cab when using, had to replace the controller as it cooked.  And ex-coworker in Montgomery County MO damaged his Green Combine re-seeder by welding on a piece he did not think was of any significance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2022 at 10:41am
That's been the case since the mid 70s when the mandated and failed "121" ABS brake systems came into being. Welding and computers don't play well together, even a stray voltage spike form a vehicles own electrical system will foul things up. Like bad grounds and rust. Aren't computer controlled vehicles just the greatest, NOT. I'm glad to be old enough the all my pre computer vehicles will outlast me and I'll never need to own one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2022 at 6:55pm
The sad thing is  they CAN play together IF the 'computers' are properly designed and built but to save a few pennies they aren't.
 I designed/built remote energy control systems 3 decades ago never EVER had a failure due to welders or Mother Nature. One system was in a huge building FULL of welders (all 3 phase of course...), no problems. Another had cables on the roof to connect 3 buildings(1,000ft more or less) . Mother Nature lit up the sky... took out the companies terminals and such, my stuff kept on working.
Don't get me going on CANbus ! Greatest CONjob of the century...... Ihad to TELL the local NIssan dealership's high priced electronic techs WHERE the problem was in wife's car AFTER they'd had it 3 times ( can't find fault )....using their $$$$ diagnostic rigs. My homebuilt $20 CANbus 'tester' found it though.....
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2022 at 7:40pm
so how do these rig welders with brand new trucks weld on the beds off thier trucks and almost always with the ground clamped to the bed my welding rigs are old but i have worked with guys with the brand new 2021 welding up parts on the back of the bed,  i have always grounded as close as possible to my work and i have never had any problems . i think all tot of times somone allready had problem and needed to blame it on the welder
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2022 at 8:41pm
When I worked at the International dealership we had a unit that the guys clamped to the batteries across all terminals. Looked kinda like a load tester. Then welded away. Never had any issues. Some of the guys still preferred to unhook batteries.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2022 at 6:29am
cuz Jay built it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2022 at 6:42am
One of the first cautions in owners books on modern electronics machines is if have to weld on it, disconnect battery.
dee_veloper View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote dee_veloper Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2022 at 1:09pm
The Chilton Ford service manual I have for my truck says to disconnect the battery and ABS system before doing any welding.
Don't confuse my personality with my attitude.
My personality is who I am. My attitude depends on who you are.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2022 at 8:59pm
them rig hands spend many hours a day welding on the back off them new duelly pickups aint seen a one them disconect ther battery
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2022 at 10:19pm
I unhook the ground cable and never weld with electric going though a bearing.
