D17 series1 brakes |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5489 |
Topic: D17 series1 brakesPosted: 26 Nov 2022 at 4:46pm |
Finally started a job that I’ve been dreading since I bought the ole girl. I knew the brakes were bad on the right side when I bought it this year which factored into my offer for it. So I soaked the pins from the bottom access hole Kroil about a week ago. Had my local machine shop make a puller like the ones you can buy but out of heavier steel. I couldn’t believe it but I hardly had to wrench it before being able to pull it out. Pulled the brakes and verified the damaged to the drum. It will have to be replaced on the right side. Will replace seals while I’m in there. The left side pin also seams to move easily although I didn’t finish pulling it because I need 1 one good brake to put her on my trailer to take it to my buddy’s shop so I can use his overhead hoist to remove the drop housing. Left side axle seal and pinion seal is leaking so that side has to come off as well. Fun, fun
AC720Man
Posted: 27 Nov 2022 at 6:53am |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4285 |
Posted: 27 Nov 2022 at 7:23am |
You're way ahead of the game just having the pins out! My success rate with the puller is probably around 30%.
AC720Man
Posted: 27 Nov 2022 at 1:03pm |
I’ve heard lots of stories about the pins being rusted in place, heads breaking off while pulling. I firmly believe the Kroil did its job, it’s been a great product for me for a long time. The right side brakes haven’t been touched for a long time as the picture shows the damage from neglect. I did take a long punch and tap the pin for about 10 hits hoping to loosen it. Not sure if that helped but they came loose easily. I’m really dreading the next step to get to the drum.
Edited by AC720Man - 27 Nov 2022 at 1:04pm |
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9004 |
Posted: 27 Nov 2022 at 9:53pm |
Getting to it may not be your worst job...it may be removing and installing the drums.
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1612 |
Posted: 28 Nov 2022 at 8:13am |
Are you going to do the diff seals while you are in there? Save doing it again in a year or two.
Thanks(1)
Posted: 28 Nov 2022 at 9:27am |
your answer is in first post
Ed (Ont)
Posted: 28 Nov 2022 at 2:07pm |
Thanks Steve. Lol. What a dummy. My excuse is I am working with one eye - just had retina surgery!
AC720Man
Posted: 28 Nov 2022 at 2:23pm |
I have heard they are a bear to get off Steve. A few resorted to a torch after the puller failed. Hoping I won’t have to do that. My old AC dealer has a puller that he is going to let me borrow. I watched a YouTube video with a guy using a hydraulic puller. That looked sweet but no way I want to spend that kind of cash for one. Maybe I should put some Kroil on it for a few days.
Edited by AC720Man - 28 Nov 2022 at 2:24pm |
Posted: 28 Nov 2022 at 3:26pm |
BRAKE DRUM REMOVAL: Step #1. Take a 3 or 4 pound hammer and break the drum off the center hub one piece at a time !! Be careful and watch out for flying cast iron !! Step #2. Rest what's left of the brake drums hub on a solid stand. Take a large sharp chisel and with the hammer used in step #1, split the hub right at the keyway. The hub will virtually fall off. Step #3. Place all tooling back where they belong.
AC720Man
Posted: 28 Nov 2022 at 3:44pm |
Thanks Doc, that sounds like a good plan.
MACK
Posted: 28 Nov 2022 at 8:45pm |
After busting drum off, use a grinder with a cut off disc to slot hub over keywey to key, then use hammer and chisel like Dr. said. Will save a few licks with hammer. MACK
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5199 |
Posted: 29 Nov 2022 at 5:15am |
Off topic, but thank God we have guys like DrAllis and Mack (and a bunch of others) that make very hard jobs, easier with the knowledge they so willingly share with us "rookies".
Thanks to you guys !!!
AC720Man
Posted: 29 Nov 2022 at 6:40pm |
That’s for sure
