D-14 snap coupler attachment
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Topic: D-14 snap coupler attachment
    Posted: 15 Nov 2022 at 1:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2022 at 1:52pm
Here is an attachment on a D-14...kinda know what it is...anyone know for sure....I can speculate...you can if you must...thanks Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2022 at 2:44pm
That is a Power-Director release. If you hit a big rock or root with a plow or whatever it will kick the PD into neutral.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2022 at 3:49pm
yup, Paul B is right ! I have one 'on the shelf, somewhere', came off 'Troy'.
Only rocks that hurt me are the softball sized ones the rototiller finds.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2022 at 4:30pm
Paul is probably right..where does it attach to the PD...could not find a schematic of one in the books...anyone have one...Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2022 at 4:39pm
Has nothing to do with the snap coupler.  It mounts to the hand clutch.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2022 at 7:58pm
Myron
You can see in your picture one end of the rod is attached to the PD Lever.
What is the mechanism the other end of the rod is attached to, and how does it work?
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2022 at 8:29pm
Originally posted by Gary Gary wrote:
Myron
Gary
Its attached to the traction booster spring, in the bell coupler.  Idea is to stop the forward motion instead of allowing the TB to transfer weight. Gives you the option of lifting the plow to test the size of the rock, or to lift, as you reverse out of the situation...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2022 at 7:32am
In the original picture...nothing is attached to the PD .....kinda why I was asking...need to find a parts breakdown picture to figure it out..thanks to all ...Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2022 at 8:15am
I guess that my grade is  a D- in mechanical aptitude...my picture shows the kick out in stow position and the later picture is in operating position... still do not know how it kicks out in both PD positions...Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2022 at 1:56pm
If I remember right my dad said it only worked to kick it out of high range. Sort of like the clutch release on the WD. Had one hanging in the shop years ago.
Post Options Post Options   Thanks (1) Thanks(1)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2022 at 3:29pm
here you go.....
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2022 at 4:10pm
Jay..thanks for the parts breakdown...
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2022 at 5:07pm
Always happy to help if I can !
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2022 at 6:32pm
The linkage clamps to the Power Director lever when you need to use the kick out feature. Mine works great in both low and high range when I use the #4 subsoiler on the D14.
