190XT Power Director
meells View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote meells Quote  Post ReplyReply Direct Link To This Post Topic: 190XT Power Director
    Posted: 16 Oct 2022 at 5:00pm
I rebult the power director on my 190xt over the winter. Everything was done according to the book. I read on here to use the 7000 plates for clutch pack, so I did that as well. I put everything back together and only had low range. Even when put in high and neutral I only seemed to be in low. Can I get some pointers on what I may have done wrong?
Thanks.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2022 at 5:19pm
Simple thing but what I did wrong the first time was not line up power director housing for oil to pass thru to high side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote meells Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2022 at 5:24pm
I appreciate the response. It's been long enough I'll need refamiliarize myself with some of the steps. I believe mine is lined up properly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2022 at 5:33pm
The passageway is for low side. Always air test a Power Director clutch before rolling tractor back together.
Edited by DrAllis - 16 Oct 2022 at 5:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2022 at 6:29pm
Thanks doc couldn't remember was a long time ago when I did mine. Just knew one side didn't work because of that mistake.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2022 at 8:49am
How much air pressure is required for the air pressure test?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2022 at 8:55am
Shop air pressure is best, but 50 lbs should be enough to KNOW the both clutches can and will apply.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2022 at 8:52pm
Thanks Dr.  I will write that information down in my power director notes.
