HC Wheels
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Topic: HC Wheels
    Posted: 14 Oct 2022 at 2:21pm
Were these AC wheels? Maybe the same used on D17HC?
Edited by orangereborn - 14 Oct 2022 at 2:29pm
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2022 at 6:15pm
Maybe Massey? have been told they fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2022 at 8:21pm
38" Wheels.  Factory option.  A lot of Massey tractors used the very same rims and centers.  That's why the centers are red in this picture.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2022 at 8:11am
Massey 65 "High Arch" are the same centers as D-17, 170/175, 180/185 that have the optional 38" wheels. The only difference is the eccentrics have a square head and A-C has a hex head. M-F 50 "High Arch" 38's centers are the same as optional 38's on a D-14/15 I used M-F centers on my D-17IVd
Edited by Calvin Schmidt - 15 Oct 2022 at 8:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2022 at 12:54am
Would the eccentric be similar to those on the CA?  Also the pictured wheels are 42 inch...I had not seen that option.  Little different extension concept to me.  Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2022 at 4:19am
IIRR, the Massey clamps are slightly different (other than the square head), too.  Might be the angle that they fit on the rails, again, if IIRR...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2022 at 7:06am
I used the eccentrics that came with the M-F centers on rims the came from an A-C. On the rim rails, some have the hole for the block drilled right angles to the rail (M-F ?) and some are right angles to the axle (A-C) The eccentrics are the same as a CA, D-10/12.
