HC Wheels |
orangereborn ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: NW WI Points: 1458 |
![]() ![]() ![]() ![]() ![]() Posted: 14 Oct 2022 at 2:21pm |
Were these AC wheels? Maybe the same used on D17HC?
Edited by orangereborn - 14 Oct 2022 at 2:29pm |
jiminnd ![]() Orange Level ![]() Joined: 16 Sep 2009 Location: Rutland ND Points: 2272 |
Maybe Massey? have been told they fit.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7441 |
38" Wheels. Factory option. A lot of Massey tractors used the very same rims and centers. That's why the centers are red in this picture.
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4529 |
Massey 65 "High Arch" are the same centers as D-17, 170/175, 180/185 that have the optional 38" wheels. The only difference is the eccentrics have a square head and A-C has a hex head. M-F 50 "High Arch" 38's centers are the same as optional 38's on a D-14/15 I used M-F centers on my D-17IVd
Edited by Calvin Schmidt - 15 Oct 2022 at 8:12am |
Would the eccentric be similar to those on the CA? Also the pictured wheels are 42 inch...I had not seen that option. Little different extension concept to me. Dale
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 53310 |
IIRR, the Massey clamps are slightly different (other than the square head), too. Might be the angle that they fit on the rails, again, if IIRR...
I used the eccentrics that came with the M-F centers on rims the came from an A-C. On the rim rails, some have the hole for the block drilled right angles to the rail (M-F ?) and some are right angles to the axle (A-C) The eccentrics are the same as a CA, D-10/12.
