WTB - WD Block
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Topic: WTB - WD Block
    Posted: 05 Oct 2022 at 10:15pm
I'm looking to buy a good WD block. I'm in south central KS/north central OK but I do head through MO and IL on occasion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2022 at 6:44am
You could also use a WC block and if you want to upgrade a little, a WD45 block works too.
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2022 at 2:47pm
I have a good WD block that I have started to rebuild.  It has NOS .040 over pistons and sleeves that were machined .040 as well.  I have everything but the crank.  The crank I had turned out to be a 45 crank and I had intended to use it with 6 volts so i wanted to leave it original.  I wound up not purchasing the tractor I was going to put it in, so I would sell it.  I have everything except the crankshaft.
Give me a call if you are interested and I can explain it further and answer any questions you might have.  816 898 7277.
Michael
The 15th Annual Exclusive AC Swap Meet will be held in Boonville, MO, March 6-7, 2026. See the club website for details: http://www.moacclub.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2022 at 12:23am
Thanks DrAllis. Hopefully I can find a WD block but that's a little silly of me. Any of those would be functional and fine for this tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2022 at 12:32am
Thanks Michael. I already have new pistons, liners, etc. in the rebuild kit I got so I'm really just looking for a bare block for now.
John
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2022 at 10:14pm
I have a WD block here in NW MO It has been tanked and Mag, It belongs to Tony Carbaugh. Let me Know if interested and I will get you in contact with him.
Albert
1947WC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2022 at 6:54pm
I have a  WD  block.  I live in Shell Lake Wi.  50.dollarss.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2022 at 6:08am
John did you buy the WD down in Bennington?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2022 at 11:08pm
No, this is a tractor I started working on 2 years ago and didn't get to looking at this part of the block until now. If I'd known better I could've made a point to check this spot out earlier in the process and already had a replacement block by now.
Thanks to all for the offers so far. I have a couple of leads I am chasing down.
