Brake controllers |
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6610 |
Topic: Brake controllersPosted: 06 Oct 2022 at 7:30pm |
Does anyone have any recommendations on brand and model of brake controller? I had a Tekonsha Voyager in my 99 F150 that lasted 11 years and when it failed I replaced it with the same model. It has only lasted a few months and now only works by using the manual override. No fun driving in traffic. When working properly it is a good controller. Thanks a in advance.
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35689 |
Posted: 07 Oct 2022 at 4:21am |
I still prefer Tekonsha, dealt with other models other people had me install and will not use others.
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25259 |
Posted: 07 Oct 2022 at 6:09am |
I've got both, whole box full ( pulls from scrapped trucks...) somewhere in the garage. Got bored one day, designed and built my own.One of those 'napkin drawings' that actually worked and then some.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 07 Oct 2022 at 6:39am |
The old fashioned ones that have a hydraulic brake line to activate them are the only ones I trust. As far as I know they are not made any more. When I got a 93 truck, I was told by trailer dealers, that I could not use this type due to the ABS (All Brakes Suck). After reading the owners manual for the 93 it says that any connected controller could not have a piston displacement more than 0.10 in/3. Any controller I've ever had, the displacement was less than that.
I've had a few different "electronic" controllers and didn't like any of them. Also I've never know of anyone using an electronic controller that didn't have a horror story to tell of when the controller didn't activate the brakes at some point when they were absolutely needed. For my "air braked" truck I got one that has an air line to activate the controller.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12421 |
Posted: 07 Oct 2022 at 7:30am |
Posted: 07 Oct 2022 at 8:09am |
both brands of controllers
Joined: 11 Sep 2009 Location: illinois Points: 90834 |
Posted: 07 Oct 2022 at 8:33am |
Tekonsha is the best around.. They are the standard for the industry... You must have got a bad one, or bad wire joint.......... I would buy another one.
Tbone95
K, um, Tekonsha and??? I guess I'm still lost.
Hubert (Ga)engine7
Posted: 11 Oct 2022 at 6:17pm |
After finally getting through customer no service I talked with one of the Tekonsha technicians. Dan walked me through setting the controller up again and it is working properly.
Posted: 11 Oct 2022 at 6:26pm |
GREAT Hubert... You should be pleased with it... That is one of the BEST controllers made.
ac fleet
Posted: 12 Oct 2022 at 4:31pm |
I had a couple Tecks.--one worked one never did! For me they are just in there and hooked up for decoration ! Cops look,---- everything hooked up------Im on my way down the road! I never go that fast anyway and most of the time not that far. IF I did a road trip then They would need to work.
Tbone95
Posted: 13 Oct 2022 at 6:33am |
So, nothing sudden or unexpected happens around you? Utopia, IL, good for you!
Posted: 13 Oct 2022 at 6:49am |
MODOT has the operator apply the controller with a second agent under the trailer. Pucks ‘click’ as magnets apply all is good, they also do a performance test on breakaway battery application, same magnet click noise expectation.
