Buying Trailer Tires
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Topic: Buying Trailer Tires
    Posted: 26 Sep 2022 at 2:48pm
I need to replace my 20+ year old trailer tires.  18ft flatbed  Has 205/75D15 LR C on it
Local tire shop has flat rate for mount and balance regardless of where the tires come from.
Looking at going up yo LR D
I would appreciate some pointers on purchase.  BTW don't want them to pop on the first run.  Confused
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2022 at 3:17pm
Dave I just checked with my old tire suppliers, Carlisle D's should cost you in the neighborhood of $88.26 each.   Goodyear D's in the neighborhood of $117.00 each + mounting and balancing. Yes, we found out trailer tires can use balancing if you are on the highway all the time.
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2022 at 3:19pm
Spend the extra money and stay far far away from the Chinese maypops
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2022 at 5:04pm
I currently have Coopers, been good for my usage.
Darwin W. Kurtz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darwin W. Kurtz Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2022 at 5:12pm
heavy load range truck tires far outlast any trailer special tire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2022 at 5:55pm
Id never buy Goodyear junk !
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2022 at 6:01pm
X2... In over 50 years I've never ever had a Goodyear tire wear out, the casing will always give up before it wears out. I even had a new Goodyear tire that was up under a pickup bed that had never touched the road just blow out in the spare rack.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2022 at 6:17pm
Originally posted by Darwin W. Kurtz Darwin W. Kurtz wrote:
heavy load range truck tires far outlast any trailer special tire. Somebody correct me if I'm wrong but I was under the impression putting a truck tire on a trailer was verboten.
I am still confident of this;
Wait for the Lord;
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2022 at 7:04pm
I’ve had great luck with Firestone HT tires. Use them on both dually & trailer. Keep them rotated for even wear & 80psi. Worn thread tires finish as Gravity wagon tires. Since year 2000, I’ve never had one of them pop!
Edited by AC7060IL - 26 Sep 2022 at 7:40pm
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2022 at 8:05pm
I've had several sets of the Firestone "HT" series tires on my Dodge dually over the years. Truck was always heavy so all six replaced at the same time. Still have one new but they have changed to the "HT2" variant now so I'll find another NOS tire someplace to run this one out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darwin W. Kurtz Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2022 at 10:25pm
Firestone HT's have been good on our Dodge
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2022 at 5:21am
Truck rated load range is not a problem, automotive rated even as load rated is a problem. ST coding is preferred.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darwin W. Kurtz Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2022 at 9:04am
Goodyear makes or markets many other brands. Some of which I actually thought were independent companies on their own. I too have not had very good results with Goodyear tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2022 at 3:54pm
Ran D or E rated tires on my tri-axle and tandem trailers for years and no problem with DOT inspection stickers as long as tated load and use were per commercial rating and not passinger car or low gvw so called truck .
This page was generated in 0.191 seconds.
