replacing steering shaft bushing?
Chad_in_PDX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad_in_PDX Quote  Post ReplyReply Direct Link To This Post Topic: replacing steering shaft bushing?
    Posted: 18 Sep 2022 at 10:32pm
The upper steering shaft bushing on my 1940 B is badly worn. What is the general process for replacing this bushing? Pain in the but job?
Thanks in advance.
Chad
10ptjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 10ptjim Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2022 at 10:54pm
take steering wheel off, loosen clamp on steering box for the sleeve, slide sleeve off, will probably have to take off tin for tool box to get sleeve off, knock bushing out on way off, install new one, put back together, not terrible to do, just rebuilt gemmar box on our 38B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2022 at 8:08am
Is it bushing 210475
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad_in_PDX Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2022 at 8:19am
Mike, if you are asking me, I’m not sure. I’m making the bushing. 1.375 OD, 0.750” ID. Can’t stomach paying $30 for a little plastic bushing.
Chad
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2022 at 1:42pm
Probably need a few choice words to complete the job.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2022 at 6:49pm
Jim, pull the steering wheel first and look down the hole.. I have been able to pick them out or push down 1 inch to get out of the way... New bushing only needs to go into the tube just below the surface so the wheel will fit back on..
Seems like you have to dimple the tube or put glue on the bushing to keep it where you want it ..
