hd5b outboard bearing
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Topic: hd5b outboard bearing
    Posted: 07 Dec 2010 at 4:52am
well, it finally happened, big repairs on the hd5b bulldozer. the outboard bearing bolted to the track frame went bad, chewed the shaft and needs a new one. i have all the parts but finding time is the issue. my question is, what lubricates these bearings as i am sure the other side is not happy either. i thought there were 2 styles of shafts, one solid and one with a hole drilled in it to allow final drive oil to get to the bearing. i thought dad had put the shafts with the holes in them and i had the finals full but no lube killed the bearing. should i drill and tap and install a grease fitting on the cover? i have a hd5g that i now need to add this to the list of things to check.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 10:21am
Yes there were 2 axels , one with the wick , and also small and large spline for the sprocket.
 A lot of machines did have a grease zerk on the outboard bearing as a modification (unsure if it was owner or dealer install) but not factory update. That bearing is a link-belt bearing and is not handled by most bearing houses.
 Have seen them also just filled with 90W as well as gun grease. as it is a timken style bearing but barrel shaped rollers and main purpose was for the occelllation of the tractor or dozer truck frame, on a 5G or 6G they do not get as much stress
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 5:24pm
i have several good bearings and i want to fill it back up with OOOgrade grease so it is very liquidish. not going to rely on the wick this time. my only concern is the seal, i have a few good ones and i am just going to hope the boots hold up. i will put a grease fitting in it to give it the few shots a year whether it needs it or not. i have the coarse spline sprockets. i also have a beautifus set of track rails with pins and bushings shot that i would love to find new for but everyone i ask says discontinued. when the outboard bearing goes bad it wears the rails all kinda funky.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 9:50am
I had one set of rails that were still at servicable height that i just had new pins and bushings pressed into. There are parts out there just getting harder to find them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 7:09pm
where did you find them? i have tried thill tractor, berco, and several other aftermarket undercarriage companies. i would love to find a set as i think they would last the rest of my life for the amount i run it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 8:52pm
BAD WORD CHOICE (that I just had )  was a while back , what i meant to say was,( had p & b  in set of track done )
 Might try Northern Tractor in Osseo MN, also Crawler Welding in Mankato MN
Also Norther Engine in Duluth MN area
I did get some  2-71 parts from Northwest Diesel Parts  / think Superior WI a few years back , blower lobe, bearings and such for blower. 715-398-7780
there were 2 axels with large spline / one rifle drilled for wick and one solid.
Edited by Coke-in-MN - 08 Dec 2010 at 8:54pm
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 10:42am
John Deere Corn Head Grease NLG0 should work for that!
