New to me D15 |
Travis2766
Joined: 26 Aug 2015 Location: Amherst, Wi Points: 439 |
Topic: New to me D15Posted: 07 Sep 2022 at 9:32pm |
New to me 1963 Series II D15, Missing the carb and the neighbor told me it hasn’t ran in 25 years, been sitting inside the whole time. Figured it was worth the $300 they were asking. Did the first year of the series 2 come with a pan style seat or did someone change it?
190XT Series III, D17 Series IV, D15 Series II, All Crop 66, Rotobaler.
Joined: 11 Sep 2009 Location: illinois Points: 91042 |
Posted: 07 Sep 2022 at 10:07pm |
i think you got your moneys worth !!
Wispitfiremike
Joined: 28 Mar 2017 Location: Milwaukee, WI Points: 210 |
Posted: 08 Sep 2022 at 12:41am |
Got your moneys worth and then some. Would have been worth the usual chatter about the number of toys/ projects I have going.
Randy WI
Joined: 22 Jan 2014 Location: Ogema, WI Points: 863 |
Thanks(1)
Posted: 08 Sep 2022 at 4:36am |
pie weights are worth more than that.
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55332 |
Posted: 08 Sep 2022 at 4:46am |
Get the serial number and post it. Series 2 was not a pan seat. Doesn't mean you got a bad deal, or it isn't a series 2, just that part swapping on a 59 year old tractor is possible/likely...
Posted: 08 Sep 2022 at 5:38am |
Pan seat was standard equipment. Deeluxe seat was an option. Power steering was an option. Hour meter was an option. Belt pulley was an accessory.
Edited by DrAllis - 08 Sep 2022 at 5:38am |
Travis2766
Posted: 08 Sep 2022 at 6:12am |
Serial number is is in the 14000’s, it has power steering, no hours meter, no tachometer and of course the belt pulley. Looks like it has the wrong seat (unless the deluxe was optional at the time), the wrong steering wheel and the decals are wrong.
Edited by Travis2766 - 08 Sep 2022 at 6:21am |
Posted: 08 Sep 2022 at 6:25am |
It's been repainted and has incorrect hood decals.
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4989 |
Posted: 08 Sep 2022 at 12:51pm |
Did you wear a mask ? You stole that.
Walter(MO)
Joined: 26 Dec 2009 Location: Warrenton, MO Points: 127 |
Posted: 08 Sep 2022 at 5:54pm |
Oval muffler and fenders with hand grips are Series II feathers.
Walter(MO)
Posted: 08 Sep 2022 at 5:58pm |
I mis typed features. Sorry.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7644 |
Posted: 08 Sep 2022 at 6:19pm |
Definitely a Series 2. Taller fenders with headlights mounted on them. Also has a dry air cleaner. As Dr. Allis said, it's been repainted with incorrect decals. Nice straight tractor - you definitely got a steal.
EPALLIS
Joined: 12 Sep 2009 Location: Illinois Points: 1171 |
Posted: 08 Sep 2022 at 9:21pm |
$300? Good grief. I'll I can say is thanks for saving another A-C before it got melted down and sent to China. The D-15 is my fav. As the Good Dr. stated the iron pan seat was standard. Black and White padded seat and back was an option. I have both. The padded seat is much nicer, so if you can find one go that route. Although I found a nice pad to put over the top of the iron seat and its fine as well. Good luck whichever you decide. Keep us posted on how it runs once you get the new carb installed.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5490 |
Posted: 08 Sep 2022 at 9:33pm |
I paid $300 for my WD a few years ago and you got a way better deal than I did. D15 series II is one of our favorites on our farm. As said the pie weights are worth more than that. You got a great deal. I’m sure you have already checked to make sure the engine isn’t stuck? Tires even look like they are in good shape.
Edited by AC720Man - 08 Sep 2022 at 9:36pm |
DonDittmar
Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2517 |
Posted: 09 Sep 2022 at 6:06am |
The Saginaw Tractor 3pt on the back is worth more than 300.00
DonDittmar
Posted: 09 Sep 2022 at 6:08am |
In fact if you dont want that 3pt, ill give you 300.00 cash for it---then you can tell the wife you got the tractor for free
Travis2766
Posted: 09 Sep 2022 at 9:11pm |
Thanks for the offer but this is the first tractor I haven’t had to talk her into letting me buy!
Travis2766
Posted: 29 Nov 2022 at 3:50pm |
Got the D15 running the other day, ended up finding the original carb for it in the neighbors shed along with the drawbar hanger assembly and strap and 3 point top link (still no drawbar, quite the mess in there!). Rebuilt the carb, cleaned all the tar from the gas tank, new sediment bowl assembly (old one crumbled in my hand), new fuel line, new plugs, changed coolant, changed oil and filter. Put it all back together and wouldn't start. Reset the timing and cleaned up the points/condenser and fired right up! Runs great, everything mechanical works and doesn't jump out of gear! Glad I was able to save it from the scrapper. Now its time to rewire since none of the gauges work, but at least the lights do! Also swap the muffler to a new one and decide if I'm happy or not with the single hydraulic service port, want to cut hay with it but I'm not big on chaining up the 3 point so the jury is still out on upgrading the hydraulic to a two way valve.
Posted: 29 Nov 2022 at 4:13pm |
do you know why it was PARKED in the beginning ? Seems like it didnt take much to get it going.. Maybe they just stopped farming ?
Pat the Plumber CIL
Posted: 29 Nov 2022 at 5:43pm |
Glad you got it going, they are a nice little tractor.
Travis2766
Posted: 29 Nov 2022 at 7:03pm |
Not sure why it got parked, it wasn’t on a farm just a rural property. I bought it from the owner’s daughter, he passed away last year and she wanted to get rid of things so the family could settle the estate. She didn’t know much about the history of the tractor just that it’s been sitting in the same spot as long as she could remember. She said she would take scrap price since it wasn’t running.
EPALLIS
Posted: 30 Nov 2022 at 8:02pm |
Thanks for saving my favorite, the D-15 Series II. The engineers in West Allis I'm confident also thankyou. As for the price you paid, well that was robbery without a gun. Very happy for you. Congrats on your purchase and enjoy the ride!
