Screw "A" Location WD45 |
Whittwhitt
Topic: Screw "A" Location WD45Posted: 05 Sep 2022 at 9:08am |
Our '57 WD45 is having trouble with the 3 point wanting to drift upwards or downwards when it should be holding in place. We've looked online at the diagram that tells you what screws to tighten and loosen, but we're having trouble locating screw "A". Any suggestions?
Whittwhitt
Posted: 05 Sep 2022 at 9:11am |
Also - please explain things as detailed as possible if you can, even with pictures. We're just starting out and are learning as we go.
Posted: 05 Sep 2022 at 9:15am |
Owners manual has a picture. Decal on the side of the battery box does too. Screw "A" is located behind the right side frame with the PTO push/pull rod running right by it. There is a divot on the side of the hydraulic pump body that the tip of screw "A" must screw into. Do NOT overtighten as it will bend things !!
