Hydraulic relief valve; 190 |
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8782 |
Topic: Hydraulic relief valve; 190Posted: 25 Aug 2022 at 10:12am |
Ok, I need my memory refreshed.
10-15 years ago, on my very early one ninety snap coupler tractor, I had weak lift on the lift arms. Upon some advice obtained through here, I swapped the relief valves around between the lift arm valve section, and the remote couplers valves. Got good lift function then, and have gotten by with the remote couplers being weak. Until now. I need the remote couplers to be up to snuff. At one time I had a couple of agco parts to repair the relief valve with, but have no idea now where they are. Can someone help me out with what parts/part numbers I need to fix er up with? I wouldn't be opposed to just screwing in a complete nee relief valve, if it's still available from somewhere. Thanks, Darrel |
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2494 |
Posted: 25 Aug 2022 at 7:41pm |
Rustle up a 3000 psi or higher gauge and see where you're at to begin with. You should be able to adjust the relief valve and see if it raises the pressure. It could also be a blown seal in the pump.
Posted: 25 Aug 2022 at 9:11pm |
You swapped the Traction Booster relief valve with the main relief valve. Main is 2200 psi and T boost is 2100 psi. Trouble with your complaint is this: the lift arms and remotes are on the SAME relief valve. Check out what you have at the remotes and go from there.
rw
Joined: 28 Oct 2009 Location: United States Points: 388 |
Posted: 26 Aug 2022 at 3:57am |
I got a new one from agco dealer this summer.
darrel in ND
Posted: 26 Aug 2022 at 6:31am |
It is possible that I am thinking of something different, but I was sure that it was on this tractor that I did this. It was several years ago, so maybe I am not remembering correctly. I haven't had time to really do any troubleshooting yet, but I'll get on it this weekend hopefully, and report back. Thanks, Darrel |
