Char-Lynn torque generator
waldersha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote waldersha Quote  Post ReplyReply Direct Link To This Post Topic: Char-Lynn torque generator
    Posted: 21 Aug 2022 at 4:01am
Putting together my WD45. Have a char-lynn power steering setup, but it has been unhooked. It is a 100 series torque generator, I believe 101. Can someone tell me which port is in and which out? I don’t see any indication on the port block or the body itself and don’t want to hook it up backwards.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2022 at 7:45am
This is a link to the power steering thread I did a couple of years ago. In the second to last picture on the second page you can see the pressure line in the top port. If your torque generator is 'clocked' the same this will work for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waldersha Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2022 at 2:05pm
Thanks for your response. Mine is set up slightly different with the generator on the bottom side of the bracket, but was able to use your pic and get it installed. Much appreciated!
This page was generated in 0.035 seconds.
