72 combine parts
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Topic: 72 combine parts
    Posted: 29 Apr 2020 at 9:16am
I know not many still actively use a 72 pull type....because I do...have a number of spare parts and pieces here in central Indiana....If you need something..will search donor combines I have for parts...Mark...Or if you just need rebuilding advice...can probably help...
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2020 at 4:14pm
Thanks for looking...my cell number is in my profile....and it is not a prison cell!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2020 at 6:26am
Glad to hear that LOLLOLLOL
onesimus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote onesimus Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 1:46pm
Do you have header lift cylinder for a 72?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 6:54am
That cylinder was typically single acting and matched the brand of tractor you were using....New and used cylinders are readily available...Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote onesimus Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2020 at 2:36pm
Would you have a wheat screen for a 72 for sale? That fits in the finishing sieve.thanks
james6600 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote james6600 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2020 at 12:24pm
I have a 72 I’m wanting to restore. I’m between Indy and Ft Wayne. Where are you located?
Post Options Post Options   Thanks (0) Thanks(0)   Quote onesimus Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2020 at 7:04pm
I live in central Arkansas. Near Cabot, AR
jtwright62 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jtwright62 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2022 at 10:34am
Hi, After rebuilding the Reel on my AC72 I headed to the field for the first time to use the machine.  On the way down my driveway I had a tree jump right out in front of of the left had side and wrinkled up the nose and the sheet metal directly behind.  I can play tin smith with most of it but I would like to replace the nose piece and a two position rock guard.  Would you have any that you could part with and how much can I give you for them?
JTWRIGHT62
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2022 at 6:33pm
I wish I knew you needed one earlier!! I got the right hand one off a 72 in Southern Illinois that was getting parted out. Sometimes it's all about timing. Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote jtwright62 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2022 at 7:52pm
IT's on par with the way my luck has been with this adventure.
