HELP IDENTIFY HD 11
Dukec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dukec Quote  Post ReplyReply Direct Link To This Post Topic: HELP IDENTIFY HD 11
    Posted: 25 Jul 2022 at 6:44pm
Hello
New here and trying to identify an HD 11.
There is no tag that I can find on the machine.  I did find a number stamped on the steel shell on the left side of the radiator area
- 09 3312.
The machine has a hydraulic blade with a tag. Model 11 H5  Serial 131
There is also a Carco winch on the back - Model F7
Any help would be appreciated.
Thanks
Duke
AC Mel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2022 at 8:12pm
Duke......Post some pictures....we here at the forum should be able to put your brain on overload...LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dukec Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2022 at 4:00pm
Ok Mel
I will see what I can do.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2022 at 4:37pm
Right Upper Rear Face of Final casing will have S/N stamped into it, the CARCO may block some of it from view.
Edited by DMiller - 27 Jul 2022 at 4:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2022 at 8:40pm
Duke...Dave's right.....If you have a CARCO winch that looks something like this...it's hard to see....most of the time that slot fills with dirt.
It will be on the case...past the winch control cable....you can almost read this one....HD11S...   just get some pictures posted and it will be easy...and fun to help you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dukec Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2022 at 3:32pm
I thought I had a couple of pictures loaded but they didn't take.
So to see the serial do I need to be on the right rear corner looking at the casing?
How big are the numbers?
Thanks
Duke
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dukec Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2022 at 6:14pm
Finally found the serial number - 5785
Now that I have that what can be found out about this machine?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2022 at 7:55pm
We can tell you that it's a 1957 year model.....and as I soon as I can get PHOTOBUCKET to work I'll get your pictures posted and we'll tell a lot more
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2022 at 8:13pm
I am still have some used parts for HD11
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2022 at 3:26pm
Ok...been trying to post these pictures for Duke before we even found the serial number
Looks like a nice specimen
Lanova style engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2022 at 3:28pm
Ok....I'm not happy with the size of the pictures...oh well
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dukec Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2022 at 3:53pm
Mel
Thanks for posting the pictures.
Does the serial tell you the year?  5785 - 1957?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2022 at 4:03pm
Actually I made a mistake...it's 1959 year model.. It looks like serial no.4768-5801 were 59
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2022 at 6:47am
Lanova engine by Nozzle placement
