Gleaner transmissions
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner transmissions
    Posted: 24 Jul 2022 at 1:30pm
Can anyone tell me which other transmissions are interchangeable with one in an E3 combine? I am pretty sure the K is. Would the F be the same?
Asking for a neighbor.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2022 at 4:02pm
No way an "F". Probably a K.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2022 at 7:57am
DseriesIV, probably all older model Es & all early model Ks(1969-1977). Should check part number though?? I can check later when I’m back in my office.
Later 7-25-22 Edit/update:The older E trans’ beam/tube assy MOUNTINGS differs from EIII/K/K2 models. The E’s trans mountings are positioned on top of their trans. The EIII/K/K2’s trans mountings are positioned on front of their trans. Hence the difference in their CASE trans part#s as follows.
E parts catalog, May 1967 shows following;
Case, trans 71131408(prior trans 3-63-0001).
Case, trans 71131690(Eff. Trans 3-63-0001&up).
EIII/K parts catalog,Sept 1972 shows following;
E3 & K trans case assy part# is 71151727.
K trans shafts,axle drives differ @ sn18601.(may or may not affect, trans swap??)
EIII/K trans clutch bell housing part# 71145047.
71141628-beam asy,axle(EIII;prior an K 5001).May or may not affect swap?
71153760-beam asy,axle(Eff. An K 5001-8201). May or may not affect swap?
K2/F2 parts catalog, Oct 1978 shows following;
K2 trans case assy part# 71151727 (same as EIII/K).
Note; the 71151727 EIII/K/K2 transmissions should readily interchange. The E will not readily interchange to EIII/K/K2s without at least beam/tube fabrications.
While doing a 71151727 trans swap, take the opportunity to RE-SEAL drive shaft SEALS (2 - Left & Right sides, part# 71145028) on usable trans before re-installing it.
Edited by AC7060IL - 26 Jul 2022 at 12:51am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2022 at 5:33pm
My neighbor just bought a K that has been sitting many years.  Looks to be an older one, so hopefully the transmission will fit the E3 without any major problems.
fjdrill View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote fjdrill Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2022 at 7:31pm
Early k and E3 the same. I went to south central MS and cut up a K for parts. I salvaged everything except engine for my E3.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2022 at 12:50am
Back to top because of edits/updates
This page was generated in 0.048 seconds.
