21C PROJECT |
AC Mel
Thanks(2)
Topic: 21C PROJECTPosted: 22 Jul 2022 at 3:03pm |
Well everyone knows we have more AC projects started and less finished than anyone on the forum.....well hell...lets start another one. Many of you know that all our timberland and range land burned in 2017. So we did some salvage logging and a minimal amount of cleanup.....always planning on a big assault on site prep brush raking.... both for forestry planting and range land improvements. Still not enough hours in the day....so I did an evaluation in the yard and thought...ok what's the biggest tractor we have that we could make serviceable the quickest...... How about a 21C! ![]() Been sitting for quite some time but we got it started and moved to the wash rack So grandson Trenton is on the pressure washer......then we'll be on a search for the brake problem. As I mentioned in the video.....we might have some access to this FD30 for parts ![]() We believe all the 30 parts are interchangeable with the 21C ![]() ![]() If we can get this thing serviceable...we'll look into the FD30 parts.
Edited by AC Mel - 22 Jul 2022 at 3:09pm |
Ian Beale
Joined: 03 Oct 2011 Location: New South Wales Points: 1009 |
Posted: 23 Jul 2022 at 5:41am |
Mel
What engine in the FD 30? A couple neighbours have around here have Iveco V8's but seems some had Cummins From the neighbours there is a modern starter that is a lot lighter and more effective.
Joined: 11 Sep 2009 Location: illinois Points: 90763 |
Posted: 23 Jul 2022 at 8:30am |
i have not been on a 21C for 30 years... Always enjoyed operating them.
The FD30 was a new version of the 21C... The FD30 had the V8 IVECO engine and a new transmission based on the FD20 Italian tractor... I think the torque converter was the same... Basically the final drives and steering were the same or very similar.. I think thats what Mel means.... should be a lot of "parts" that can move from one tractor to the other..
DougG
Posted: 23 Jul 2022 at 9:11am |
Geesh theres some metal there! What does it weigh ?
Posted: 23 Jul 2022 at 9:40am |
fully loaded with the ripper and blade............ your in the 80,000 pound range.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42262 |
Posted: 23 Jul 2022 at 10:19am |
Kind of makes my FD5 look like a toy - but then the FD5 sure out worked the HD5B it replaced . Looks like the Grouser Bars on the 21C never met the ground
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4873 |
Posted: 23 Jul 2022 at 10:49am |
Uncle had a 69 HD 21 with the Ateco hinge ripper as the orange 21 on the left of Mel's one picture without a ROPS was over 42 ton. I did not know the FD 30 was that closely related to the 21's. As uncle had one of those too after a wile. Did the late 21's and FD 30's have improvements to final drives?
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35647 |
Posted: 23 Jul 2022 at 12:23pm |
Is the UC associable to any other machines Mel, or is it that same unobtanium as most Allis?
HD6 Merv
Joined: 03 Aug 2010 Location: New Zealand Points: 501 |
Posted: 23 Jul 2022 at 4:47pm |
fwiw HD21 track chains are 9.00 pitch. . .same as D8H.
Many moons ago when i was young and had hair. . . we took the track chains off a customers HD21A and put them on his early D8H. Think we had to add 2 links ?? |
tits tyres and tracks
they all cost you money |
Posted: 23 Jul 2022 at 5:34pm |
That is a good thing
Ian Beale
Posted: 23 Jul 2022 at 6:59pm |
Ray
We had a nest of Allis owners around here - 16's and 21's. Story I heard is that 21's had a problem with expanding the eye of one of the final drive bearings which was fixed in 21C's. Seems that the 16's didn't have the problem.
rcwitzel
Posted: 29 Jul 2022 at 8:03am |
AC Mel - I have a binder full of Fiat-Allis 21-C service manuals. They cover final drives, engine, cab, steering clutches and brakes...etc. The binder includes an operations and maintenance manual. Most look like they just came out of the printer. Send me a private message if you want them.
R.KYLE
Posted: 04 Aug 2022 at 7:41pm |
GOOD INFO. MOST INTERESTING.
