190xt
rickymotorbrains View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickymotorbrains Quote  Post ReplyReply Direct Link To This Post Topic: 190xt
    Posted: 11 Jul 2022 at 9:07am
looking for some engine parts used for the 190xt diesel turbo motor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2022 at 9:21am
What are you looking for ?? I have a complete engine that is stuck, but complete.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickymotorbrains Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2022 at 10:17am
the cam and hydraulic pump adapter and front timeing cover
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2022 at 10:19am
Camshaft I can do, but hydraulic pump adapter I do not have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickymotorbrains Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2022 at 10:23am
what would you want for the cam and front cover
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2022 at 10:37am
My engine is a combine engine, so the front cover isn't the same. My camshaft is the newer design like a 200 tractor with the 4 inch long bolt in the nose to prevent the cam from breaking from hydraulic pump loading. I'd take $400 for the camshaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickymotorbrains Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2022 at 1:50pm
ok thanks mine is the older stile where the oil pump runs on cam
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2022 at 4:00pm
Yeah well, this is exactly what you would get if you bought new. It still drives the engine oil pump the same way, just has an updated/improved nose to prevent breakage.
This page was generated in 0.172 seconds.
