170 cough? |
dewn81 ![]() Silver Level ![]() Joined: 30 May 2010 Location: East Central Mo Points: 65 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Dec 2010 at 7:23pm |
What would cause a 170 gas to cough a couple to few times before it throttles up?
norm[ind] ![]() Orange Level ![]() Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
CARB PROBLEMS --AIR LEAK ON MANIFOLD????
cold air
Thanks for the fast replys . But i wouldnt think it would be the cold air since it aslo does it during the summer. Thank you
Claus ![]() Orange Level ![]() ![]() Joined: 09 Dec 2009 Location: Hebron In Points: 1154 |
Intake manifold gaskets probably need replacing.
Eldon (WA) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
I'd check the carb gasket first....the shape of these and the way they bolted together was not a good design. Also check the main jet, I ran one for two years with the choke out before I found out the main jet had come loose. |
ALLIS EXPRESS!
This year: |
bump
JoeO(CMO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
could be running a little lean
LouSWPA ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25051 |
I dunno, but try a couple of Ludens lemon honey flavored drops
I know, I know, I apologize, sometimes I just can't help myself
I am still confident of this;
bump
Have you tried anything yet?
No i havent been able to check it out today. But i do know that engine is up for a major overhaul so would that casue it to. Or would it be mostly a carb. and manifold issue?
Get a can of WD40 and next time you have it running, spray WD all around the carb mounting gasket, the manifold gasket and the throttle shaft bushing. If RMS's increase from spraying it, you have an air leak that needs to be fixed.
