HD5 dozer |
BiG210
Topic: HD5 dozerPosted: 04 Dec 2010 at 6:40pm |
I'am looking for a blade to fit a 1953 model hd5 thank you
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42269 |
Posted: 04 Dec 2010 at 6:58pm |
Just blade or full dozer set up , several mfg made the units , Most used a system to run arms to the rear Axel outboard bearing flange to use as the push base.
Lift systems varied in where they had bearing point on the truck frame as the truck oscillate unlike the 5G which had a solid truck frame cross-member.
here is one I had not seen before in type of lift as it uses tractor mainframe as part of lift hardware.
Edited by Coke-in-MN - 04 Dec 2010 at 7:01pm |
BiG210
Posted: 04 Dec 2010 at 7:04pm |
Just the blade is what i need it has a hyd fram that goes from the rear around the front to single pin hole in the front i think maybe garwood or backer but don't know thanks
dadsdozerhd5b
Joined: 27 Sep 2009 Location: lansdale pa. Points: 537 |
Posted: 05 Dec 2010 at 4:27pm |
i have a baker blade setup i was just thinking of scrapping. i will send you a pm with pics. |
