front wheel bolt pattern
edmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote edmo Quote  Post ReplyReply Direct Link To This Post Topic: front wheel bolt pattern
    Posted: 12 Jun 2022 at 5:26pm
 Ok, going to get a spare set of wheels and tires for my D-15, Series II.  It has 5-lug rims and  came with 6.50x16's.  I need to get the same bolt pattern and the right wheel width.  If I mesasured correctly , it measured 5" from center of ist hole to far side of 3rd hole which should make it a 5 on 5 i think. Tires are on so cant measure wheel width accurately but tractor data for d-15 says 4.5", at least for series!,  Said nothing about series II width.  Would 4,5 be right for 6.50 x16's?  They didn't appear to be an option with the series 1 (only 5.50x 16).
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2022 at 5:43pm
if you GOOGLE D15 front rims, you normally see that the front were 4.25 x 16 inch 5 bolt on the EARLY tractors and 4.5 x 16 6 bolt on the later...
i think there was a 5.5 x 16 inch rime, 5 bolt for the early D17.
Edited by steve(ill) - 12 Jun 2022 at 5:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2022 at 5:51pm
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2022 at 10:13pm
Ed make sure you get tractor rims. Wagon rims can be had with the same bolt pattern and same width. But the centers of the wagon rims are made of thinner metal. If someone on here doesn't have some, a tractor salvage yards is where I'd start looking.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2022 at 10:54pm
My dad told me that the rims from a 1950 Buick and only the '50 Buick will fit a WD45. I have no idea if this helps with a D15.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2022 at 7:33am
That must be what the ones I have are.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2022 at 8:54am
Automotive rims on a tractor drive me insane 🤯🤯
Darrel
