Sediment bulb |
| Author | |||
dbro2
Joined: 28 Oct 2018 Location: Loveleand, Ohio Points: 8 |
Topic: Sediment bulbPosted: 08 Jun 2022 at 2:58pm |
I purchased a 185 diesel recently. I experienced a loss of power while using it to disc. I removed the sediment bulb expecting to find a screen. There is not one. My first question is where can I get one. Secondly I cleaned the bulb of some debris and cleaned the stem and was able to get a steady stream of fuel. I could not tell if there is a second hole in the stem that is clogged. My second question: Should there be more than one stream filling the bowl. I also changed the fuel filter and all of the above solved the problem. Thanks for the info.
| Sponsored Links | |||
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7530 |
Posted: 08 Jun 2022 at 3:21pm |
Yes, there must be a screen in the sediment bowl. There should also be 2 streams coming out when you open the valve. Screens can be found almost anywhere. I get mine from Steiners. My guess is that your tank has a lot of crud in it and the previous owner removed the screen to improve fuel flow. Clean out the tank and refill with fresh fuel and you should be good to go.
dbro2
Posted: 08 Jun 2022 at 3:39pm |
Thanks I knew it should have a screen and suspected that there should be two streams, I will get a better light.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5052 |
Posted: 08 Jun 2022 at 5:13pm |
I will take the opposite side. With the cartridge fuel filter on a 185 there is no reason to have a screen in the sediment bowl. It is just an extra place for a fuel restriction. I say leave the screen out.
You could have a restriction in the the top of the sediment bowl housing. It narrows down significantly and tends to catch chunks of rust or debris that have found it's way into the fuel tank. Drain the tank, remove the sediment bowl assembly, try to flush the tank until there is no more debris and replace the sediment bowl assembly without the screen. Edited by WF owner - 08 Jun 2022 at 5:17pm |
FREEDGUY
Posted: 08 Jun 2022 at 5:17pm |
How can you take a "side" when you don't know WHAT the OP has upstream from the bowl for a filter ![]() ??We NEVER had an issue with the screen in the bowls of a 180 gasser, XT ,and F2 . This poor guy isn't heading towards a fuel pump rebuild due to the lack of maintenance from the previous owner
.Edited by FREEDGUY - 08 Jun 2022 at 5:22pm |
WF owner
Posted: 08 Jun 2022 at 5:19pm |
Having a screen in the sediment bowl is redundant. The 185 has a filter cartridge. A screen is just a place to restrict the fuel supply. By the way, "upstream" would be before the sediment bowl. The sediment bowl screws directly into the fuel tank. There is no place to have something "upstream from the bowl".
Edited by WF owner - 08 Jun 2022 at 5:22pm |
FREEDGUY
Posted: 08 Jun 2022 at 5:23pm |
FREEDGUY
Posted: 08 Jun 2022 at 5:25pm |
point taken on the "stream" segment. Is this "inline filter" delegated to the 185 ?
WF owner
Posted: 08 Jun 2022 at 5:29pm |
Most, if not all, Allis Chalmers diesels had a fuel filter other than the sediment bowl.
FREEDGUY
Posted: 08 Jun 2022 at 5:39pm |
[QUOTE=WF owner]Most, if not all, Allis Chalmers diesels had a fuel filter other than the sediment bowl.[/QUOTE
OMG !!!! Are you talking about the canister filter between the hand primer and the actual fuel pump ! ???? You made it sound like an "in-line" bubble filter in the lawn mower gas lines That little screen in the bowl was a LOT less of a headache to clean than having to prime/purge the entire system when changing the canister filter
![]() Edited by FREEDGUY - 08 Jun 2022 at 5:44pm |
Joined: 11 Sep 2009 Location: illinois Points: 88431 |
Posted: 08 Jun 2022 at 5:53pm |
the canister filter will hold 15 TIMES as much crud as the little screen..
WF owner
Posted: 08 Jun 2022 at 5:59pm |
At least 15 times and probably much more.
WF owner
Posted: 08 Jun 2022 at 6:05pm |
You have to remember that many mechanical injection pumps (Roosa Master and Standyne for sure) get all their lubrication from the diesel fuel. Starving an injection pump for fuel is similar to starving an engine of oil.
The sediment bowl has very limited capacity for storing dirt before it restricts the fuel flow. I remember one mechanic at our local AC dealer telling customers to remove the screen and throw it away. We did that and never had any problems.
caledonian
Silver Level Access
Posted: 09 Jun 2022 at 6:23pm |
Use clean fuel with a filter on your storage tank in the future. We have always left the screens in with no problems.
FREEDGUY
Posted: 09 Jun 2022 at 6:50pm |
[QUOTE=steve(ill)]the canister filter will hold 15 TIMES as much crud as the little screen..[/QUOTE
Why would you want 15 X to get that far ??
Posted: 09 Jun 2022 at 7:01pm |
Winter time tractor use ?? that screen is the FIRST place the fuel will gell !!! Throw it away !!
DCAC
Joined: 20 Oct 2018 Location: east central SD Points: 512 |
Posted: 09 Jun 2022 at 7:36pm |
I've used NAPA 3039 filters in place of the screen and have had good luck so far. They won't fit in the smaller bowls though.
