2800 turbo line |
ACmutt
Topic: 2800 turbo linePosted: 26 May 2022 at 9:48am |
When installing a turbo on a 2800 non turbo engine, where do you hook the oil line going to the turbo?
Posted: 26 May 2022 at 6:28pm |
All the way along the right side of the engine block is the main oil galley. It has the oil pressure idiot light sender attached to it. There should be a plug or two to tap into all along the block. Bigger hole the better. Have you got the turbo drain line plumbed ??
Edited by DrAllis - 26 May 2022 at 6:28pm |
ACmutt
Posted: 27 May 2022 at 7:01am |
Thanks Dr. There are 2 places, one has the light, both are small. There is a plug at the bottom of the engine block, right side right under them. I haven’t taken it out yet but though I could use that for the return? Don’t know if I can get it out, where do you suggest I go with the return??
Edited by ACmutt - 27 May 2022 at 5:40pm |
DougG
Posted: 27 May 2022 at 2:27pm |
That maybe the coolant drain !!!! Ill have to look at some of mine
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9005 |
Posted: 28 May 2022 at 9:32am |
those galley plugs are 1/8 pipe on my 426's and that's where the turbo feed is
