Disc Identification - not AC
cgraffeo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cgraffeo Quote  Post ReplyReply Direct Link To This Post Topic: Disc Identification - not AC
    Posted: 05 May 2022 at 12:45pm
Hi all,
I have an old disc that has broken, and I am attempting to find the parts for it, however can not seem to find the make.  It's not AC, but I figured someone might recognize it.  The part that is broken is the bearing housing that attaches to the frame, both broke as they are cast iron and the axle has come off as a result.  Unfortunately now is the time I need it haha!  I've attached photos of all the numbers I could find, one on the disc bearing , left side says "KK" right side says "2700-B".  I took this as "King Kutter". however when I called them they said they have no idea what it is...
The number on the axle looks like it is KK2703-6?  maybe B?
Let me know if there is any additional info I can help supply or if you recognize it at all!
Thanks in advance
Edited by cgraffeo - 05 May 2022 at 12:48pm
John m View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John m Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2022 at 3:17pm
Guessing old Oliver or JD. Looks like green paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cgraffeo Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2022 at 4:38pm
Oh man John, I think you have something there!
I didn't notice the green paint, but you are right.  I looked up on ebay and I found that John Deere disc harrow bearings have a similar number pattern
https://www.ebay.com/itm/324708733847?hash=item4b9a261397:g:MCEAAOSwWyhg6I3m
IE:KK4401B .
I'll have to look into that a bit more I think
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2022 at 8:03pm
You might want look up Case too. Dad had 1 similar in 1959. It was a Case.
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 9:39am
John Deere would have the "JD" casted on its parts. Case would have the eagle casted in their's. I'm guessing Oliver by the numbers. They used "E, X, B, P, and C in their casting codes.
Edited by steelwheelAcjim - 06 May 2022 at 9:40am
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
