1978 Allis Chalmers 7000
Allis Man 64 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Man 64 Quote  Post ReplyReply Direct Link To This Post Topic: 1978 Allis Chalmers 7000
    Posted: 24 Apr 2022 at 8:29pm
I am looking to sell my Allis 7000. There is 7160 hours on it. Interior is in ok condition but could probably use a new cab kit. It has been taking up space in the shed and no longer have a use for it. The tractor starts and runs good overall.
I purchased this tractor 20+ years ago. There’s an Isaacson Implement Co Inc. sticker on the door frame. Assuming that’s where it was purchased new.
Call or text (507)-696-0007 for more info. Thanks!
Edited by Allis Man 64 - 24 Apr 2022 at 10:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2022 at 9:24pm
That is the cab serial number. That tractor is a 1978.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Man 64 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2022 at 10:07pm
Didn’t realize the cab serial was different from the tractor serial #. Where do you find the serial # for the tractor?
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2022 at 10:22pm
Location?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2022 at 6:20am
Right rear side of the rear end housing vertically. That is a black belly tractor with wet-clutch and TEE handle shifter on the console. They came out in late summer/early fall of 1978.  I'd guess your chassis s/n might be 8001 to 8005 ??  The cab was changed from the previous 1975 thru mid 1978 models, so they started a new s/n range. Did they match chassis s/n 8001 with cab s/n 1001 ??  I doubt it, but you tell me.
troym View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote troym Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2022 at 7:14am
Isaacson is no longer in business they closed about 6 years ago i believe, they were located in Nerstrand Minnesota.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2022 at 8:37am
The tractor appears to have the heavy front axle option. That would be a plus in my opinion.
