looking for metric bolts
Roger Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Mn Quote  Post ReplyReply Direct Link To This Post Topic: looking for metric bolts
    Posted: 30 Nov 2010 at 6:53am
Need 12 M20 X 2.00 X 65mm    Roger
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 7:05am
Don't know if you are close to a specialty bolt supply house.  In Omaha, we have Nebraska/Iowa fastener.  They had a 6" long metric bolt I needed, could even choose the hardness.
Greg Kroeker
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 8:21am
I think Lowes has Metric, not sure if they have your size/threads.
Fastenal also has, check their website.
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 8:40am
I used to own a Yamaha motorcycle and snowmobile shop. We dealt mostly with metric. If you can't find any, let me know and I can probably get you some. Otherwise, try any Japanese motorcycle shop, such as Yamaha, Honda, Suzuki or Kawasaki shop. Perhaps a local foreign car dealer would have it, such as a Honda or Kia dealer.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 8:45am
Just look in your yellow pages for a dealer under Bolts & Nuts and also under Fasteners-Industrial & Construction.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 8:56am
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 9:24am
www.mcmaster.com has them in grade 8.8 and stainless steel but 2.5mm pitch, not 2mm pitch. The grade 8.8 is partly threaded, the two in stainless steel are fully threaded hex head. I didn't look for socket head. http://www.mcmaster.com/param/asp/psearch.asp?FAM=cap&FT_110=48195&FT_104=141&FT_1349=232268&FT_136=45180&FT_379=122672&FT_147=60655&FT_137=31621&FT_1464=61711&FT_182=47456&FT_2025=130285&FT_2234=257255&FT_2029=100006&ppe=3&session=desc=Screws;cap;110=48195;104=141;1349=232268;136=45180;M;I  $2.99 each for grade 8.8
Or just bring up www.mcmaster.com. Click on bolts, click on hex head, click on metric, click on 20 mm diameter, click on 65mm length. The two stainless are quite a bit more costly that the zinc p]ated steel. They do have them in socket head also, but still 2.5 mm pitch.
Fastenal has 1.5mm pitch with 1- 2 weeks delivery time, $5.70 to $15 each.
2.0 mm may be a tough size to find.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 10:17am
What/ where are these being used?  It might be easier to match from that angle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Mn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 10:32am
putting loader brackets on a deutz DX130
Dale H. ECIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale H. ECIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 6:57pm
I needed a metric bolt for the draw bar on my 5030 a couple years ago, looked every where, finally tried Fastenal and they had it.
Allis Chalmers Museum, Paris, Il.http:// www.allischalmersmuseum.com 217-275-3428
Dave King View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave King Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 7:11pm
John Deere usually carries metric, but Fastenal is better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 8:21pm
you might want to check your thread pitch again.. 2.0 is not a standard size..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Mn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2010 at 7:28am
I was able to find the some bolts . thanks for the help Roger
