Wd45 crank |
d17brown ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: farley iowa Points: 1722 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Apr 2022 at 3:40pm |
What is casting number on a wd45 crank
phil
JK in Pa ![]() Bronze Level ![]() ![]() Joined: 12 Sep 2009 Location: Dushore, Pa. Points: 164 |
226535 is the main one. There are a couple of others depending on original use as per tapered hole, woodruff, or key way in nose.
Never saw a keyway in a 45 crankshaft, only D17 and up. MACK
