Ball Hitch Planter ....
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Ball Hitch Planter ....
    Posted: 01 Apr 2022 at 6:46pm
Guy that pulled a planter with a ball hitch system on his planter/tractor ?? What's his "forum name" and where's he been ??
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2022 at 7:10pm
If I’m not mistaken didn’t John Deere have a few models years ago with that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2022 at 7:21pm
This guy was/is a member on here and NAT, seems like he worked for the Ford tractor plant on the P/S tranny and then ended up at JD on the same project?? He did the ball hitch on his own in the early '80's ?? Thanksfor the reply
Edited by FREEDGUY - 01 Apr 2022 at 7:22pm
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2022 at 8:15pm
Old JD 490 planters had a ball hitch, also 494 planters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2022 at 9:07pm
If I recall, didn’t those planters have a chain/cable on each side of the hitch, and those activated the row markers, when you turned around at the end of the field?
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2022 at 12:32am
Dad bought a 490 planter in 1962. It had a pin dropped in the drawbar. The pin had a loop on the top of it and another pin went through a couple of loops on the cast iron planter hitch and went through the loop on top of the pin. That pin was held in with a cotter key, nail bent over, or a clip if you could find it. My 494A was the same way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2022 at 11:54am
Yes, they controlled the markers with a chain, some of the time, if were adjusted just right it worked.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2022 at 12:45pm
Have 2 494s. Both pin hitch. A small pin that drops between two lugs and some kind lock through the lug holes. Marker control chains attach to a slingshot type frame bolted the drawbar ahead of the hitch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2022 at 6:07pm
Ball hitch, that just sounds painful, ooch eech!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2022 at 6:29pm
Sadly, I'm going to call BS on your reply, We ran a 294 A and there was NO provisions for a "ball hitch" ClapClap !! Oddly, the 494 "elongated" hitch pin area is EXCATLY the same elongated hitch on the '86 7000 CTLOLLOL!!
Yet "AGAIN" , you guys are missing the point of my post, Who's the guy that has NOT replied on here or other forums recently ?? Seems like he was from Iowa and had at LEAST TTPP but was very cordial with his info ClapClap
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2022 at 6:35pm
YES !!! It was a "U" bracket that bolted to an unused hole in the drawbar of the WD/D 15 ClapClap!!! It was a "chain" that was involved Big smileBig smile !! Man, that brings back AWESOME memories LOLLOL !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2022 at 6:38pm
[QUOTE=DiyDave]Ball hitch, that just sounds painful, ooch eech!Wink[/QUOTE
Is it "momma" or Trump getting you the "OUCHY" ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2022 at 7:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2022 at 7:16pm
Worked for a neighbor that pulled with a Farmall 656 gas, the first year I worked there, then traded if for. JD 7000 4row. Planted 700 acres a year, it was for whole 8 years I worked for them. Then went and worked for another neighbor, he had the same planter, pulled with a JI Case 830D Comfort King.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2022 at 7:37pm
The only farm equipment I have seen with ball hitches is hay balers. Thought it was a pain to have to deal with until I used it.  Pulling a 3 wire tie baler with it's own engine on it with a JD A. The ball hitch took a lot of the jerk out of that big plunger hitting by not having baler rattling around on a 3/4 pin in a 1 1/4 hole.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2022 at 11:24am
Guess I have to confess I forgot, yes it was a separate attachment for marker control, just didn't remember, planter been gone for 40 years and my memory isn't getting any better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2022 at 8:05pm
Seems like his name was Gerald ?? That was my OQ, what was his name and is he still around ??  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2022 at 8:22pm
been gone for a while...........
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2022 at 8:27pm
Thanks Steve, I hope its' just a "snafu" that he's not been on here (Gerald J) .
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2022 at 7:40pm
He’s dead.
And you are totally wrong (as usual) about him working on the PS trans.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2022 at 5:57pm
Originally posted by Jordan(OH) Jordan(OH) wrote:
He’s dead.
Well, thanks for the "death" notification (when was this ??), but are you certain about the PS tranny's ?
In hindsight, you're probably correct, Gerald was an electrical guru if memory serves Embarrassed
Edited by FREEDGUY - 07 Apr 2022 at 5:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2022 at 8:52pm
Google Harold Brock
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2022 at 8:07pm
Thanks Jordon, but I draw-the-line at "googling" people's names Cry , I won't stoop to it .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2022 at 8:10pm
Google isn’t the only search engine there is. I don’t use google. And I have no trouble finding information.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2022 at 8:19pm
IMO, it's still "snooping" Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2022 at 8:43pm
Just log on to the website of the local newspaper where someone lived, pull up the obituaries and search for the persons name. The family pays to have obituaries printed and posted on line, or in the newspaper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2022 at 4:27pm
Confused This is not snooping???
But we now know his name is Harold Brock and to look up what is on the world wide web is snooping??? Like maybe reading his obituary, which in general praising the good things the person has done, would be snooping?  Wink So I guess you are looking for gossip???LOL
This page was generated in 0.938 seconds.
