Best way………….. |
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8409 |
Topic: Best way…………..Posted: 22 Mar 2022 at 3:50pm |
to remove paint from an aluminum rim?
22.5 aluminum rim, years ago got painted black. Other than dismounting the tire, and switching rims, what is an easy, effective method of removing paint from an aluminum rim? TIA |
Joined: 11 Sep 2009 Location: illinois Points: 90980 |
Posted: 22 Mar 2022 at 4:16pm |
I put a couple coats of paint remover on and get off as much as possible with a wire brush... Then use a sand blaster... If tire is too big to go in the blaster, build a small plywood or cardboard box over it and a plastic window to look thru.
plummerscarin
Posted: 22 Mar 2022 at 5:57pm |
Walnut shells for blasting if paint stripper don't work. Less damage to wheel
Lars(wi)
Posted: 22 Mar 2022 at 6:49pm |
Will give paint stripper, and oven cleaner a try. If they don’t work, then I’ll switch rims, don’t have a blaster.
Posted: 22 Mar 2022 at 7:43pm |
call a local shop.. If you get 80% of it off with the stripper, they may not charge much to finish it.
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3312 |
Posted: 22 Mar 2022 at 9:02pm |
Kinda depends n what finish you want to end up with. Easiest way would be to sand it off with a random orbit sander. Start with 60 grit paper and work your way up to 220 grit. Will leave a nice smooth finish that is easy to polish.
For polishing I use a 5" variable speed sander/polisher from Harbor Freight with a 6" sewn cotton buffing wheel and a stick of red polishing rouge. With a little time, you can make it shine like a mirror. |
Lars(wi)
Posted: 22 Mar 2022 at 10:00pm |
Don’t need it shine like a mirror, as it’s a company delivery truck. A 1995 KW T800 w/3406e, and Eaton Super 10.
shameless dude
Posted: 23 Mar 2022 at 1:16am |
folks around here take their rims to the local monument company to have them blasted. dunno what they would charge, but they keep going back so maybe it ain't to spensive?
