rust bullet |
Ed in TX
Joined: 11 Sep 2009 Location: Beaumont, Texas Points: 400 |
Topic: rust bulletPosted: 28 Nov 2010 at 3:36pm |
Anyone have any experience with this? I want to paint the inside of the rims before I mount up some tires. Anyone have a better plan? I don't have a way to blast them I was going to run a wire wheel over them and use this stuff.
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2577 |
Posted: 28 Nov 2010 at 3:41pm |
Never used that before. Just did one of my WD rims. Used a wire brush then 3 coats of Rustoleum primer. I hope to notice an exterior leak before it eats through 3 thick coats of primer.
AaronSEIA
Adam in VA
Joined: 01 Oct 2009 Location: Timberville,VA Points: 55 |
I haven't used this product myself, but I have seen it around before. I know a few people who use it. They have been using it on shed and barn roofs and not tractors. I haven't asked them exactly how well it works, but these guys are pretty particular so it must be alright for them to use it, at least on roofing.
Edited by Adam in VA - 28 Nov 2010 at 3:44pm |
D21,D19,(2)D17,190XT,ED40, WD45,WC,B,25-40(Thresherman's Special),5030 plus buildings full of other stuff
427435
Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
Posted: 28 Nov 2010 at 4:15pm |
I've had good luck with a product called Extend for neutralizing and coating rusty surfaces. POR15 is also supposed to be good------a lot of old car restoration people use it.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
GBACBFan
Joined: 11 Sep 2009 Location: Green Bay WI Points: 2662 |
Posted: 28 Nov 2010 at 8:25pm |
If you clean them good, either blasting or wire brush, wipe them down with denatured alcohol, and slather the inside with your favorite red oxide primer, they'll outlast both of us.
are genuine." - Mark Twain |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7566 |
Posted: 28 Nov 2010 at 9:43pm |
I vote for sandblasting, priming and painting as well.
ALinIL
Joined: 20 Sep 2009 Location: Frankfort, IL Points: 316 |
Posted: 29 Nov 2010 at 12:38pm |
Ed - Have you ever thought of using cold-galv paint. It's about $10/aerosol can. You will need about 1.5 cans per wheel. Just prep the rim and spray. Check McMaster-Carr under zinc-rich paint. - AL
