wd 45 hydralic pump |
gman11110
Topic: wd 45 hydralic pumpPosted: 28 Feb 2022 at 8:03am |
my hydralics on my wd45 are very weak. do they make a rebuild kit or do I just replace o-rings any help is appreciated
oldfords
Bronze Level Access
Joined: 31 Mar 2020 Location: South Dakota Points: 52 |
Posted: 28 Feb 2022 at 9:21am |
When you say the hyd are weak, does that mean they are slow or that they won't lift. If you have a pressure gauge, you can hook in and see the pressure. If it is low, you might get by just by shimming the relief valve in the pump. If they are slow you will need to look into the pump and see why. Could be rollers, springs o-rings, ect. I just rebuilt the pump in a friends D-15 and found it was better to buy just the parts I needed rather than trying to find a kit.
Dakota Dave
Posted: 28 Feb 2022 at 9:23am |
there really aren't O rings to change. screw the relief vale all the way in them back out. try it it may loosen the stuck valve but probally not. take the pump off the tractor its only 4 bolts and will come out from behind the frame. dissasemble it and free up the stuck check balls and check for broken spring. most of the time stuck check balls are the cause for pump not working correctly.
gman11110
Posted: 28 Feb 2022 at 9:26am |
yes they are slow and wont lift me if i stand on lift arms. can you just match up the orings if nothing else looks bad
gman11110
Posted: 28 Feb 2022 at 9:28am |
very good thats what i was planning to do remove pump and clean it up real good. tractor sat up for years. I rebuilt engine and got it going,
gman11110
Posted: 28 Feb 2022 at 9:30am |
what releif valve are you talking about
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4760 |
Posted: 28 Feb 2022 at 11:19am |
Never been into a wd 45 but it is just as possible the packing in the lift cylinder is bad as the pump is going bad. So get a gauge and check pressure, cheap and easy.Well if this is one of the high pressure system AC's made a gauge maybe higher priced. But still test before just throwing parts at it.
I have been down the road of fixing pumps before and not fixed a thing.
gman11110
Posted: 28 Feb 2022 at 11:32am |
very good point i will check pressure
Posted: 28 Feb 2022 at 12:25pm |
Get your Orings from AGCO or chances are you'll get to do it again. They are not dime store Orings. They are better quality that that.
1963D17
Joined: 05 Jun 2021 Location: Alvord, Iowa Points: 90 |
Posted: 28 Feb 2022 at 12:42pm |
Very slim chance this is it. I had a bad roller on one of the levers on one of my WD45's. Actually ruined the cam lobe on the input shaft and sent metal all thru the pump. An used shaft, pump and a lot of cleaning its worked great since.
Stan IL&TN
Posted: 28 Feb 2022 at 9:14pm |
It's not a hard pump to work on. Lay out a clean towel and keep the parts in order. There is not a rebuild kit that I know of. Mine had a broken spring so I replaced all of them including the o-rings. If any of the balls are pitted or worn replace them also and reseat the balls with a flat punch. Good luck.
1957 WD45 dad's first AC
Joined: 11 Sep 2009 Location: illinois Points: 88450 |
Posted: 28 Feb 2022 at 9:28pm |
how old is the oil ? what does it look like ? Water / milky / grey ?
MACK
Posted: 28 Feb 2022 at 9:31pm |
You have been given some bad advice from a few that don't what they are talking about. Check pressure first. If it is low, remove pump, disassemble, and check for worn parts. Replace all o rings, five springs on check balls, gaskets, and any thing you find warn. Reassemble, and reinstall on tractor. Recheck pressure and if it is low, you will need to remove pump (again) to add shims to unloading valve. MACK
1963D17
Posted: 28 Feb 2022 at 10:59pm |
I am kind of new on here. But have been in parts/service for 34 years. I am confused about the "bad advice" comment. Actually down right self conceited. I don't care who it was directed at. Of coarse installing a gauge is the next step after checking the oil level. But it is a 70 year old pump and all the advise I read was good whether common sense or personal experience. I maybe will just stay over on the Red Power forum as childlike snotty comments like that are very rare.
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6088 |
Posted: 28 Feb 2022 at 11:13pm |
Or its out of oil, or the darned adjustments for operation aren't set up right. That's what I went through with mine...
