More Juicetrician help,,,,,
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: More Juicetrician help,,,,,
    Posted: 23 Feb 2022 at 9:54am
 OK, I'm looking at a possible purchase of an electric motor for my compressor but have come up on something I've never seen,,,,!
 The motor is BIG in size but Tag does not list the HP. The dude says it was on a big two stage compressor with cylinders about 4" and 3" in size. Can someone tell me what HP the motor is based on following tag numbers,,,,,,,,,,,,,,,,
 Model=   78 182TCDR7026AA WCW
 Frame= 182T
 Type  CDR-LE
 RPM= 1750
 Serial = 638868
 volt=  115/230
 AMP= 23.2 / 11.6
AMB 40° C
 The tag does not list motor Mfgr either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2022 at 10:11am
easy...
230 volts x 11.4 amps = 2,662 watts
2662/745 = 3.57 HP
so... consider this to be a 3.5HP motor
now 'big' in size could mean it's OLD....
the 'frame' style/number is kinda important as it tells you the mounting stuff(holes,sizes, shaft distance from ground....)
have a look at the shaft diameter ! it 'could' be 5/8, 3/4, 1, 1 1/8.....even an oddball size like 7/8".......
hmm 1750 so 'low' speed ,check what YOU have. Most 'modern' air compressors run 'high speed' motors (3450+-)..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2022 at 12:55pm
182T is the FRAME SIZE... that tells you the bolt pattern / shaft diameter ..... The motor is BIG because it runs 1750 rpm so needs  a lot more "STUFF" inside to put out the HP... if it was a 3400 rpm motor , it would be much smaller...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2022 at 1:33pm
you could use a 182T or a 184T motor of 3 HP single phase........ both will have a 1-1/8 inch shaft and both will be the same distance from the front mounting holes to the pulley... the 184T would be slightly  bigger base as the back two holes would be an inch further back from the pulley as compared to the 182T
any other "frame size" motor would be a smaller/ larger shaft size and different base bolt pattern.
this is a basic idea of what you need... again, it is a 184T and not a 182T so the bolt pattern is off 1 inch in the BACK.. .. shaft / HP / and front mount are all the same as 182T
Edited by steve(ill) - 23 Feb 2022 at 1:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2022 at 3:21pm
OK, I gotta ask....
what the heck is 'farm duty' ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2022 at 4:32pm
well TEFC mean "totally enclosed".... so that keeps the DUST out if your loading grain, etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2022 at 9:34pm
 TEFC is Totally Enclosed Fan Cooled,,,,but I KNEW Steve knew that already,,,,,LOLLOL
OK, I'll go back in my cawnor,,,,,,,,,,Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2022 at 6:08am
seems they also have higher starting torque and an external reset(overload) red button compared to 'regular' motors.
