yellow forklift blues... |
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25223 |
Topic: yellow forklift blues...Posted: 09 Feb 2022 at 10:12am |
sigh.. anyone know if it's possible to actually remove/replace the starter in an FPD50... with the Buda 4BD153 diesel engine in it ?? 3 bolts hold it onto the bell housing (3rd bolt looks 'fun') Starter gets lots of power, click, doesn't spin though. Not batteries Not 'stuck' (spun flywheel with prybar) Not 'electrical' aka wiring Also can I remove the 'starter starter' ? Box on top of the motor section. I can remove the bolt connecting power to the 'strap' going to the motor, 'think' I can get the slotted screws holding the 'housing' to the starter mtg plate also anyone have a real part number for one ?? All 'words of wisdom' appreciated..actually nice here +2,sunny which is good cause ,of course, it's outside, won't start and flat tire....I KNEW I should have left it in the 50* garage...sigh.. jay
Edited by jaybmiller - 09 Feb 2022 at 10:42am |
Posted: 09 Feb 2022 at 1:45pm |
Only took me 5.5 HOURS to remove it.... good thing is NO bandaids..... Have NO idea HOW to get it put back in though..
Eric B
Joined: 09 Feb 2012 Location: British Columbi Points: 1009 |
Posted: 09 Feb 2022 at 6:48pm |
Congrats on getting the starter out! When we're retired, time isn't the biggest obstacle... it's being patient when we tackle these 'huff & puff' jobs. You can take comfort in the fact that you're well ahead of the 'book time' for doing this on a BMW car! We're looking forward to your post about getting the starter back in and everything working well again!
Posted: 14 Feb 2022 at 3:28pm |
Got starter back ,next day... .. new solenoid, new bendix, 4 new brushes ,good to go---$200 out the door THAT was the deal of the day, worth get scared on the QEW with a very oversized load taking 3 of the 5 lanes(weeving) doing 120KMH aka 72 MPH. and you wonder why 'truckers' get a bad rap ?
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11397 |
Posted: 15 Feb 2022 at 1:07pm |
Wow that sounds dangerous to be on the same road as he waas.
Posted: 15 Feb 2022 at 1:34pm |
same stretch of road the dump truck driver HIT the Burlington Bay Skyway bridge(dump trailer was UP !!!). yeah, google that, read it, then reply when your head stops shaking !
Eric B
Posted: 15 Feb 2022 at 3:28pm |
So Jay... for all the trouble you had getting the starter out, how long did it take to put it back in?
Posted: 16 Feb 2022 at 6:50am |
Took about an hour. Normal ,healthy guy it'd be a 10 minute job. First it's heavy and I can't lean over, 2nd you NEED a 9/16,custom shallow MAGNETIC socket on a 1/4" drive setup,3rd, you REMOVE the air intake elbow 'adapter' FIRST....,4th..it'd be quicker if it didn't have the custom ABS PCV (blowby) system to reattach... Once everything was 'buttoned up', turn ign on,3 quirts of ether,pedal to metal, turn to start, vroom.....once warmed up, drove to garage to patch the patched tube in the right rear tire.Ongoing battle..no tires available, lousy innertubes. Actually thinking I could cut down a 5.8-12 tire use as a 'liner' between innertube and real tire.Naturally I tossed 3 of them out last year cleaning up next door.. Oh well, she's next door,in the old D-14 #4 shed. So 'all is well'
