PD//TA ?? |
Page 12> |
| Author | |||
FREEDGUY
Topic: PD//TA ??Posted: 09 Feb 2022 at 5:33pm |
Allis had the Pd, IH had the TA. In that era of tractors, did any manufacture offer a "shift-on-the-go" tranny ?? I've been on the seat of several 5/6/7 models of Olivers but I don't recall a "power shift" tranny
. Thanks
| Sponsored Links | |||
ryan(IN)
Joined: 11 Sep 2009 Location: Bluffton,IN Points: 792 |
Posted: 09 Feb 2022 at 5:47pm |
Oliver had the over under
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62 |
FREEDGUY
Posted: 09 Feb 2022 at 6:13pm |
Could that be shifted on the go ?? I know Massey had Multi Power but I don't recall that a shift on the go either
?? Thanks for the reply
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5279 |
Posted: 09 Feb 2022 at 6:35pm |
Oliver: Hydra-Power-Drive 2 speed shift on the go
Over-Under hydra shift 3 speed shift on the go Massey Ferguson: Multi Power drive 2 speed shift on the go Case: Case-o-matic drive: Shift on the go between Torque converter drive and direct drive Ford: Select-O-Speed 10 speed total shift on the go Minneapolis Moline: Ampli-Torque 2 speed shift on the go International Harvester: Torque Amplifier 2 speed shift on the go. The advantage Allis Chalmers had over all the rest was Neutral in the middle, everyone else was either or. Seat warmers sometimes never knew what all the levers did as they never read operators manuals
FREEDGUY
Posted: 09 Feb 2022 at 6:57pm |
Thanks Paul. I've been in the seat of a MF 180 and that short stubby MP stick did NOT look shift-on-the- go friendly to me
!! None of the 550/770/880 Olivers I drove had Hydra-Power. There were no Case O Matics in our area, the next door neighbor had the Ford (801?) select-o-speed but that's a little different animal than I was asking about .The only MM machine was a combine 40 miles away from our area, no MM tractors at all. There were a lot of White tractors in the area for a while , any size from a 2-70 to a 4-225
Kevin in WA
Joined: 08 Feb 2010 Location: Lynden, WA Points: 615 |
Posted: 09 Feb 2022 at 9:52pm |
The AC Power Director didn't free wheel in low like a lot of others did.
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Posted: 10 Feb 2022 at 5:59am |
The 2 speed/3 speed oliver shift was after the 770/880 series. 1700/1800 series.
Charlie
Charlie175
Posted: 10 Feb 2022 at 6:03am |
JD had the Power shift in the late 60's and also the 2 speed Quad range transmission that came out on the 4030 if I remember. But these are 10-15 years newer than the IH/AC/OL designs.
Charlie
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5204 |
Posted: 10 Feb 2022 at 7:11am |
Ford had dual power 2 speed buttons on the floor like the AC PD, but ford was way before, on the 8000/9000. Of any of the ones mentioned above, I know of none with a neutral in between. The AC early PD is the only ones I can think of with a neutral in between.
Edited by injpumpEd - 10 Feb 2022 at 7:12am |
Posted: 10 Feb 2022 at 7:19am |
Deere 4020 power shift was introduced in late 1963.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12422 |
Posted: 10 Feb 2022 at 9:57am |
What the heck would "shift on the go friendly" look like then? Short and stubby would seem to indicate very little effort required. I first shifted an MF Multi Power when I was about 5 or 6 years old. The Massey would freewheel in low Multi Power, and engine break in Hi, which seems a tad backwards to me, but that's how they were. What series of Allis stopped providing a neutral PD? The 7045 we have is PD, and it's either or, defaults to low of course when the clutch is depressed.
injpumpEd
Posted: 10 Feb 2022 at 12:47pm |
Last AC PD with Neutral would be the 175/185. The reason most freewheel in the low side of the 2 speed shift on the go, is the low side uses a one way sprag clutch for the low side, then the direct, or faster side simply has to engage one clutch pack making a smooth, simple shift. Many Auto transmissions also use this for low gear. The hyd TA like in a 706 and up have the sprag but also a clutch pack on the low side to provide the engine braking, or eliminating the freewheeling.
Gatz in NE
Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1064 |
Posted: 10 Feb 2022 at 12:59pm |
IIRC, the 190 had hydraulically actuated PD, is that correct?
both direct and under were positive (no free-wheeling) ? but no neutral either?
injpumpEd
Posted: 10 Feb 2022 at 2:45pm |
Yes 180/185/190/200 is hyd, positive, no sprag, but they do have neutral in between.
Gatz in NE
Posted: 10 Feb 2022 at 2:56pm |
could those models be "feathered in" where the hydraulic was under control and acted like the older PDs with The Big Stick or was it just IN / OUT ?
Tbone95
Thanks Ed, yes, I understand mechanically why it's low that freewheels. I'm just saying from the standpoint, if you're going to control your speed downhill, one would intuitively think slower would be "better/safer/smarter" than faster. ? Just my worthless thought is all.
TramwayGuy
Joined: 19 Jan 2010 Location: Northern NY Points: 11858 |
Posted: 10 Feb 2022 at 2:57pm |
The Oliver 770/880 had a available optional ‘Power Booster’ drive, which was the same principle as the IH ‘Torque Amplifier’. The later Oliver ‘Hydra Power’ and even later ‘Over/Under Hydraul Shift’ were much improved over the earlier ones.
Edited by TramwayGuy - 10 Feb 2022 at 2:58pm |
John m
Joined: 11 Apr 2020 Location: Wetmore, Mi Points: 278 |
Posted: 10 Feb 2022 at 3:57pm |
Had to read through this topic a couple times, if I'm reading it correct, my early 190xt has neutral between the high and low. The selector has three lock positions, high-neutral-low.
Kansas99
Joined: 26 Feb 2015 Location: W Kansas Points: 4868 |
Posted: 10 Feb 2022 at 4:02pm |
Don’t know if you’re supposed to but I feather my 185 constantly whe filling the cattle bunks with hay. Works fine. |
plummerscarin
Posted: 10 Feb 2022 at 5:12pm |
The detents are pretty stiff on the 185 here but have that as well with 3pt rake
Posted: 10 Feb 2022 at 5:17pm |
A good squirt of WD40 in the pivot area and on the detents makes that lever work very nice.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5476 |
Posted: 11 Feb 2022 at 10:16pm |
I’ve always been Orange since I can remember, because our family has been since 1955 with my grand dad’s new WD45. Dad continued that with his brand new Series II D15, used D14, and new 6060. I love the PD on the AC and was actually disappointed when the 6060 didn’t have one. My best friend has AC tractors but also has a mixture of Ford tractors. 3-8600’s of which I have driven many times. Dual power on the floor, shift on the go...PD with no neutral in my opinion. Although a very good tractor, our AC’s with power directors give a better option.
FREEDGUY
Posted: 12 Feb 2022 at 6:48pm |
FREEDGUY
Posted: 12 Feb 2022 at 6:54pm |
We had a neighbor that ran a 5500,6600 and 7710 Ford tractors, seems like all 3 (the 7710 for sure) could be shifted from 1 gear to another while on -the-move with NO gear grinding/clashing, a far cry from the D/100 series
Tbone95
Posted: 13 Feb 2022 at 8:03am |
Yes, of course, that was the whole point. |
FREEDGUY
Posted: 13 Feb 2022 at 4:57pm |
Thanks, I was never given instructions from the owner when I was 10 and came from D series A/C tractors
PaulB
Posted: 13 Feb 2022 at 7:48pm |
Steering wheel holder (seat warmer) that never read an operators manual.
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1606 |
Posted: 14 Feb 2022 at 7:25am |
Freedguy. The MF multi power shifted with switch on dash.Just move switch up or down. Of course you can shift lever if you want but the whole point of it was to avoid that. So on the 165, 175, 180 you had 4 speed trans and hi low range for 8 speeds. Multi power trans was a 3 speed trans so with the switch was 12 ahead and 4 reverse. Had to check on that. The older 35's and 65's had only 3 speed trans.
Edited by Ed (Ont) - 14 Feb 2022 at 7:52am |
DonDittmar
Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2517 |
Posted: 14 Feb 2022 at 8:11am |
When I was a kid we had a MF 180 with multi-power. Used it often and it was trouble free, never put a dime into it. All of the AC's we had, we had good luck with the PD with the exception of the popping back into N. Usually an adjustment fixed that.
Old timer told me it costs 1.00 everytime you shift an IH T/A. Probably up to 5.00 now LOL One neat thing about the over/under in an Oliver is it is a separate unit all together with its own housing. I think there 2 speed hydra-power is like that as well.
Ed (Ont)
Posted: 14 Feb 2022 at 8:41am |
Page 12> |
