Spray chrome
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: Spray chrome
    Posted: 29 Jan 2022 at 9:18am
Has anyone tried having this done rather than chrome plating?  The chrome pieces on the B110 I am restoring are covered in surface rust, so I have been leaning towards spray chrome as a more affordable alternative.  However I have heard that it can flake off pretty easily and does not have the same mirror finish as chrome plating.
What are your experiences?
Many thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2022 at 9:28am
Polish and wax would be better than fake chrome. You know the only real answer i$ to get it rechromed
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2022 at 10:04am
X2. I think spray chrome is just extra bright silver paint.
Having said that, I cleaned up the chrome stadium light bar on the 7045. The corrosion was worse on the top side so after cleaning, polish and wax, I sprayed the top side with the "chrome" feathering to the real chrome. Looks good from the ground
dee_veloper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dee_veloper Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2022 at 1:46pm
If it isn't too terribly rusted, you can polish it up with light oil and 1500 grit sandpaper.  I did that on my B110 and it turned out very nice.
Don't confuse my personality with my attitude.
My personality is who I am. My attitude depends on who you are.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2022 at 3:29pm
I've seen many things done with a "chrome" powdercoat. Like all powdercoat, it looks good to begin with and over time if it gets chipped or has a defect anywhere it will flake off. With most anything there is no substitute for doing a job right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2022 at 4:01pm
Have you checked local motorcycle places for chroming  ?
Real stuff is 'triple plated' , copper-nickel-chrome.... $$$
Prep is 99.44% of the job. Rest is 'easy'....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2022 at 7:58pm
It would take a ton of work to get any shine out of this grille.  The support for the arm rests is worse.  Thinking about it over the day, re-chroming would be the way to go.  Could also get the D21 grille polished at the same time!
This page was generated in 0.307 seconds.
