7010 head swap ?
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Topic: 7010 head swap ?
    Posted: 18 Jan 2022 at 5:16pm
My local independent tractor shop called today. They have a 7010 with a cracked head in for repair. It has the copper injector sleeves. Engine rebuilder guy suggested looking for the older style head. Has anyone done this swap? They know that the injector lines will be different. Will the injector pump work okay with either type of injectors ?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2022 at 6:09pm
Pump and injection lines will work, but you will have to have the injectors reconfigured for the early style nozzle and nut. A 7010 may have AC holders, or may have Bosch/AmBosch holders. I'm not sure what all on the engine will need changed.
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2022 at 10:21am
If i remember correctly, the injectors are the only thing you will need to change. I did this conversion to a 7000 ,  years ago.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2022 at 10:35am
Ed, many years ago I think it was Columbus diesel, had nuts for the two Bosh Inj that would allow for the changing of tips/nut or maybe just nut to allow swapping from the tapered nut to the flat style that used the copper washer for sealing in the non copper tube head.  Then I tried again and they said they were discontinued - you have any sources for these?
This page was generated in 0.075 seconds.
