D 15 sediment bowl |
ACinSC ![]() Orange Level ![]() Joined: 16 Dec 2015 Location: South Carolina Points: 3019 |
![]() ![]() ![]() ![]() ![]() Posted: 18 Dec 2021 at 3:52pm |
Pulled mine as I could see some rust/dirt in the bottom of the glass . Screen looks clean to me . Guess this crud is fine enough to go thru the screen ? Old gasket is rubber and I can't get it to seal . Do you fellas prefer cork or rubber ? THANKS !
REEDE ![]() Silver Level ![]() Joined: 24 Apr 2010 Points: 286 |
Any time i have opened up a sediment bowl i always put a new gasket in. Either one will work . Have never been able to reuse a old gasket.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88129 |
i bought a box of 6 rubber gaskets on e-bay for just a few $$.... Have used a couple so far.. Always good to have a couple setting around as spares.
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8727 |
soak it in oil for a bit.
Thought I had a spare but it's not the same size . I'll get one soon . Thanks
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24725 |
You can grind copper and steel pipes into 'gasket punches' and make your own, providing you KNOW where YOU put YOUR gasket material sheets.... ..., I have NO idea where mine are hiding...sigh
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21998 |
Sounds like the sediment bowl is doing exactly what it is designed to do. Sediment/debris is stopped by the screen and has settled to the bottom along with any water. Screen doesn't have to be plugged to do the job.
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3946 |
Agree with Doc. Fuel flows from the tank through the center of the fitting then up through the screen to carb line. Water and silt left to drop to the bottom of the bowl. As for leaking, dry fit the bowl to the base. If it rocks back and forth then the fitting is warped and sealing will be difficult even with a new gasket. BTDT
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5140 |
If you can't get it to seal up, the main body of the sediment bowl has been warped by overtightening. There is a reason that the only have knurling or small bumps on the tightening nut. Pliers are not supposed to be used, however that is mostly want happens and why older ones don't seal up.
Thanks for all the comments . Feel sure a new gasket will do the trick . I'll get one soon .
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5059 |
When your putting the bowl back on, just as it's starting to seat, twist the bowl and that will help it to seat and seal.
Looked thru my tractor parts boxes and found a new gasket that was the right size . Seems there's 2 different sizes ? Now if I can find a new one to buy and put in the tractor toolbox I'll be good . I have a clean and leak free sediment bowl now . THANKS for all the help everyone !!
do you have small short bowl or long bowl.
Not sure , I'd say it's a small and short bowl ? It's about 2" diameter and 1" tall .
208362 is gasket for small bowl
Thanks Mike , is that a agco number ?
70208362 for ordering agco. Older D15 right
Thanks !
the screen is 70235555
FREEDGUY ![]() Orange Level Access ![]() ![]() Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
No answer to your question, but the WORST bowl to seal IMO was on the XT190
The right one on a 190 isn't to bad but the left one is a real pain. I reuse mine many times. When I got the tractor I had to clean the bowl at least daily. It's the only tractor that sits outside. So I'm constantly drawing water from them. The cab is 6" to tall to fit thru the door.
Sadly, it was the R/H bowl that gave grief, but I think there was another factor involved (dad). Ended up replacing the entire assembly as no gasket would seal
