10% off Nelson mufflers
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Topic: 10% off Nelson mufflers
    Posted: 25 Nov 2021 at 1:35pm
SMALL BUSINESS SATURDAY SALE
phone # is 920-598-1287, email is parts@awtractor.com
Will be open Sat 9am to 7pm
#233450 fits vertical mufflers on B, C, CA, D10 <serial #9001, D12 <serial #9001, D14, D15 series I gas tractors
#248883 fits 180, 185 gas/diesel, also fits 170/175 diesel & D19 gas tractors
#237811 fits D15 series II gas, I-60 gas, I-600 gas, 615 gas tractors
#249324 fits 170 gas, 175 gas tractors
Edited by Alex09(WI) - 25 Nov 2021 at 1:37pm
www.awtractor.com
A&W TRACTOR 920-598-1287
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2021 at 9:13pm
Does the #249324 also fit a D-17 Series 4 gas?
Randy WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy WI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2021 at 7:51am
Alex do you have a simple trick to get the bolt holding the muffler on mine is rusted solid on my D14 would like a nelson muffler on but fear breaking the bolt off hoping for an easy fix. Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2021 at 10:37am
It does, only difference is outlet pipe is twice as tall and 1/4" larger (1 7/8") than D17 muffler 246129
www.awtractor.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2021 at 10:49am
No easy way, penetrating oil or/and heat. Or break it off and drill it out (reverse drill bits work best) and retap threads. The NOS bolts I have here are grade 2 so easy to drill and retap!
If your threads are 3/8, you could go with the brass bolt 226169 from WD45 muffler, but the D14/D15 parts books seem to show a 7/16" bolt used to attach muffler... Contradicts the used D15 manifold I have here which is threaded for  3/8" bolts.
www.awtractor.com
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2021 at 8:00pm
Alex, do you have any for WD's/45's?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2021 at 8:13pm
Nope, but expecting more any day now.
www.awtractor.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2021 at 7:55am
Thanks Alex.
ORBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ORBill Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2021 at 10:53am
Alex
PM sent
Bill
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2021 at 6:36pm
Heat the bolt with a torch until red, then toss a glass of water on it.  Don't overheat the bolt until it starts dripping!  This worked well on my D14 manifold bolts and I highly recommend it.  It appears that this process separates the metals back to their separate materials.
