rebuild carburetor problems
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Topic: rebuild carburetor problems
    Posted: 22 Nov 2010 at 7:07am
I had to rebuild a carb for my old WD last week, it had a Marvel tsx464 on it. The problem I am having is the power adjust needle needs a new packing where the small packing nut tightens down around the valve handle. The carb rebuild kit did not supply this part. Is this available? What have you others done in the past? It has a steady drip of gas and I am afraid to tighten it any tighter for fear of breaking the valve.  Dave.
John In. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John In. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 9:52am
 I could be wrong David, but I used teflon tape around the threads on the needle itself cause I think thats where it was leaking from.  John
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 10:00am
I have used a small "0" ring in there. Just went to local parts store and they had a good variety to choose from. Been working great.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 10:01am
 Try winding a packing from waxed string like dental floss.
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 11:02am
I have made packing out of teflon tape for sediment bowl valves, don't know what the long term effect of gasoline but so far I've out lived them.
Doug northern IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug northern IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 11:29am
there is teflon tape for oil and gas should be a yellow color roll local hardware should have it. Ive used it without any problems.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 11:41am
A good hardware store should have graphited string packing for valve stems.
Gerald J.
FredinInd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredinInd Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 2:13pm
had same problem a while back, I have an old set of leather punchs, took a piece of old leather, punched out a 3/16 in piece, took a 1/16 drill bit(new one) hand drilled a hole in the center of the leather piece, then used a fingernail file to bring it down to size. Best to work under a magnifer if your eyes not as good as they used to be. Worked great. took a little time and effort, but it doesn't leak...
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 2:23pm
I've used waxed cotton thread that is for leather stiching with success.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 5:16pm
I went with the o-ring idea after Freddie L. called and straightened me out. It seems to work fine.
