Dad's WD project |
Page 123 4> |
plummerscarin
Topic: Dad's WD projectPosted: 02 Mar 2021 at 10:45pm |
Well I started another project. This time it is a WD my dad repowered with a 262. He had found a WD diesel complete but not running. His BIL in southern Mo. ran a dealership and found a gas engine to swap in. Dad passed in '89 but I kept the tractor. It was smoking pretty bad then and then just sat till now.
![]() Engine is stuck. One rear rim was shot but I was able to salvage a piece to repair a rim for uncle's 170 and the complete tire/rim is also on the 170 for now. Planning to post more pictures and of course look for advice along the way. |
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8557 |
Posted: 03 Mar 2021 at 6:19am |
Now that looks like a project for sure! Will be watching!
These are the best ones! Family ones! Regards, Chris
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4123 |
Posted: 03 Mar 2021 at 9:09am |
That'll keep you busy awhile! Good luck with the old girl. I talked to a fellow at an auction last fall that had put a 4 cylinder diesel of some sort in a WD. He was picking my mind about how to get it finished, mentioned this forum. He's not on the net and I'm not much help with early diesels..... Maybe I'll run into him again some day?
FloydKS
Joined: 12 Sep 2009 Location: S E Kansas Points: 8431 |
Posted: 03 Mar 2021 at 9:43am |
how fast was it going backwards to bend that fender? just curious... Yes looks like a nice start to a good 'fun' project.
plummerscarin
Posted: 03 Mar 2021 at 12:45pm |
Lol. The tractor wasn't moving, but the tree that hit it was doing 140 during the Derecho.
![]() ![]() Here it's being dragged in off the tilt trailer. Since the tires are off, I removed the snap coupler set up so it would roll on the wheels. I put 2xs underneath to prevent them from gouging the floor and new trailer deck. In another thread there was discussion about hoists. Here I'm using a chain fall anchored to the lift to pull in. Funny, just yesterday I saw Ian on Full Custom Garage do this very thing.That's 3 time in 6 months I've had to do this. Now considering an anchor on the back wall with a winch should work better. |
Sugarmaker
Posted: 04 Mar 2021 at 7:07am |
Its starting to look better already!
Thanks for posting your progress! Regards, Chris
dakotawc
Joined: 17 Feb 2013 Location: Clayton SoDak Points: 58 |
Posted: 04 Mar 2021 at 7:15am |
I've seen a couple like that over the years. How did they compare to a wd45 gas powerwise?
plummerscarin
Posted: 04 Mar 2021 at 8:34am |
I was just a teen then but from my recollection, Dad wanted to pull the 3 bottom slat plow in 3rd gear which the WD45 struggled with. I remember right off the bat the transmission would pop out of third so that got fixed as well. My favorite time with it was plowing after dark and seeing the muffler glowing red.
plummerscarin
Posted: 04 Mar 2021 at 12:57pm |
Rear wheels off and on the skates to spin 180 and to the right.
![]() ![]() In position for tear down My stepson says this is where the magic happens. He redid a Nova here and is where the 170 got an engine overhaul and new clutch. |
Sugarmaker
Posted: 04 Mar 2021 at 8:05pm |
The magic area! Nice!
Looking good on the start of this project. Regards, Chris
ac hunter
Posted: 05 Mar 2021 at 7:20am |
Will be interesting to see your progress. Keep the reports and pictures coming.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5052 |
Posted: 05 Mar 2021 at 8:06am |
I would love a magic area, where I could wave a wand and it was fixed....
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12024 |
Posted: 05 Mar 2021 at 2:19pm |
Oh shoot! I thought that was those new style foldable fenders, so when you get in a tight spot, ya just fold em' in.... No? Anyway, great project. Best thing is it was your Dad's. That's really great!! If you need a special built wiring system for that when the time comes, let me know. I can work with ya on a new harness for the ole' girl......
Steve@B&B
plummerscarin
Posted: 05 Mar 2021 at 3:07pm |
Thank you Steve. Yes this harness is looking a little crusty and completely wrapped in electrical tape.
One thing I dislike about draining coolant is it can be such a messy process. I found a bit of copper tubing that I cut to fit the drain valve and routed to a bucket below. ![]() ![]() Or maybe you guys already figured this out. I was surprised how clean this coolant looked. ![]() I also fabbed one to drain 7XXX's |
Sugarmaker
Posted: 05 Mar 2021 at 7:41pm |
That is a neat idea! thanks! Now to remember it!
Regards, Chris
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6089 |
Posted: 07 Mar 2021 at 3:57pm |
Dang... here, I saw that first picture, and was hopin' that by the time I got to the bottom of the thread, I'd see it with the tracks back on!
plummerscarin
Posted: 07 Mar 2021 at 4:00pm |
Lol. Took me a while to figure that one out. Was there a conversion. Seen em on Fords
plummerscarin
Posted: 07 Mar 2021 at 7:51pm |
Teardown begins. Started with the head to assess cylinders.
![]() Not good. But had little hope. Some of it is my fault as I had the plugs out for some time. Was pouring lubricants in there hoping to loosen this stuck engine. No luck. It was smoking pretty good last it ran so figured sleeves would need replacement. ![]() Someone cut the fan shroud so I will need to repair that. |
plummerscarin
Posted: 07 Mar 2021 at 8:03pm |
There's a big dent in the bypass tube for the cooling system.
![]() I'll just put it in the vise and tap a ⅝ rod through and push the dent out. ![]() Ok what just happened? ![]() That's not the rod. ![]() Please tell me this is not someone's diabolical plan to restrict flow in the bypass. Unless someone has one, I guess I will try to braze this shut. |
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8667 |
Posted: 07 Mar 2021 at 8:16pm |
Maybe who ever flattened the tube stuck that in there to keep from total crush?....but had it lodged and couldn't remove it?
plummerscarin
Posted: 09 Mar 2021 at 6:52am |
Yeah, I don't know maybe. Would there be need to restrict flow there?. Anyway time to the rails and steering off to remove engine. I cut and drilled some 3" channel to support the torque tube once the rails are off. Had a devil of a time separating the frame from the steering box. I used pry bar at the end w/ pressure as I tapped(well, hammered) on the rail to get them apart. In hindsight maybe a large cold chisel would have been better as a wedge? Now to the steering shaft u-joint.
I could not steer this thing at all and figured moisture had gotten to the gear box. ![]() Much easier to get to shaft pin. It's a solid pin not a roll pin and stuck good. Using a separator tool to drive out the with a series of nuts and bolts as drive pins. ![]() ![]() Turns the gear box works fine. The u-joint is seized up. There is no grease zerk in it or the shaft support bushing. |
Strokendiesel002
Posted: 09 Mar 2021 at 9:14am |
Great progress so far! Sorry to see that someone sabotaged the bypass line, I really like the coolant drain tube, gonna have to borrow that idea!
plummerscarin
Posted: 10 Mar 2021 at 8:58am |
More progress
![]() ![]() Edited by plummerscarin - 10 Mar 2021 at 9:00am |
plummerscarin
Posted: 10 Mar 2021 at 11:21pm |
Engine out. Flywheel from a WD45D.
![]() Cutch apart. I see stress cracks in the pressure plate and although there seems to be plenty of material on the clutch disc, I think it is saturated with oil. Way back when I was trying to pull start it I could tell the clutch was slipping. I know the rear seals were leaking cuz it was dripping out the inspection hole back when I was rolling it inside. ![]() Needed a 3 jaw puller to remove plate from back engine ![]() That flywheel is HEAVY!! |
Steve in NJ
Posted: 11 Mar 2021 at 6:31am |
Send that PP & clutch assy off to Rick. He'll take care of that puppy!
Steve@B&B
Strokendiesel002
Posted: 11 Mar 2021 at 8:55am |
Busy night! Great job!
Sugarmaker
Posted: 12 Mar 2021 at 5:31am |
Wow! You have been busy! Lots of parts and piece. Looks like everything needs touched. I am going to get popcorn!
Regards, Chris
plummerscarin
Posted: 12 Mar 2021 at 6:51am |
Everything needs attention yes. The price you pay for wear and tear and then leave it sit so long
I thought it might be a good idea to hang the steering box on a stand. ![]() Engine on Dad's home built stand ![]() Taking lots of pictures for reference later Interesting timing mark. Unique to this engine? I do have a service manual
plummerscarin
Posted: 12 Mar 2021 at 8:06pm |
The ignition coil bracket is bolted the aluminum governor cover and yes a bolt broke off in the cover. Removed the cover to get to governor and it is crusty.
![]() Looks like a cage bearing will need a close look. ![]() I held a nut over the broken bolt and used a transfer puch try center punching the bolt. Reasonably to drill and use an easy out. The easy out was a fail so I welded a washer and nut to it. ![]() ![]() That process has worked several times for me. But I was concerned initially because I didn't want to hurt the aluminum. |
Dirt Farmer
Silver Level Access
Posted: 12 Mar 2021 at 10:32pm |
Have tried many ways of removing broken bolts but never thought of welding a washer to the broken bolt then a nut to the challenge or using a nut to help find the center to punch a starting point through. Goes to show you are never to old or experienced to learn something new. Thanks for the tips, good luck with the project and keep the pictures coming.
Page 123 4> |
