Gas Tank Holes |
44 Allis B
Joined: 30 Sep 2010 Location: Friendship, WI Points: 32 |
Topic: Gas Tank HolesPosted: 20 Nov 2010 at 6:57pm |
Putting a new wiring harness in the B today and noticed that the gas tank was really starting to leak on the bottom. There is a place where it has been repaired in the past with an external application. Looks like JB Weld. I removed the tank and noticed that there are no soft pads on the lower support bracket. A further inspection of the inside of the tank revealed allot of rust and a very bumpy corroded black surface. I think it might be to my advantage to just replace the tank with another used one. Just need to find one. Anyone know where there is a good place to buy a used tank for a reasonable price?
1945 Allis B (B70687), 1953 Farmall Super M (F12856J), 1970 Farmall 826 Diesel (2510148U015442*) & 1969 Cub Cadet 106
MNLonnie
Joined: 11 Sep 2009 Location: Baxter MN Points: 4800 |
Posted: 20 Nov 2010 at 7:07pm |
If there are no local tractor salvage yards there are 3 different guys from WI who are constantly tearing down Allis tractors and putting parts on e-bay.
Rog(NCWI)
Posted: 20 Nov 2010 at 7:17pm |
I have a gas tank that has no strap on it .It would fit a 39 B. I live east of Wausau. Email me
Dave A
Joined: 11 Sep 2009 Location: Almond Wisconsi Points: 855 |
Posted: 20 Nov 2010 at 8:09pm |
www.worthingtonagparts.com Worthington Ag Parts – www.asapagparts.com Wis Tractor Parts – Black Creek, WI 877-530-2010 www.annensmachineryranch.com - Windor, WI www.caroline-implement.com - Caroline Implement, Ed’s Tractor Repair, LLC – Englert Enterprises – S & L Tractor Parts – Gillett, WI 920-855-2240 Mark Heitman Tractor Salvage – Durand, WI 715-673-4829 Edited by Dave A - 20 Nov 2010 at 8:10pm |
Winston Churchill |
Dave A
Posted: 20 Nov 2010 at 8:14pm |
lakeside implament 608-296-2045 Harisvill.
Winston Churchill |
Stan IL&TN
Posted: 20 Nov 2010 at 9:41pm |
How about fixing the existing tank?
I've used this on three tanks with great results.
1957 WD45 dad's first AC
Osage_Orange
Posted: 20 Nov 2010 at 9:58pm |
I repaired a gas tank on a garden tractor with a fuel tank repair kit from the local auto parts store. You could consider it temporary until a replacement tank is found........FWIW
Why is there never time to do it right the first time, but always time to go back and fix it?
MACK
Posted: 20 Nov 2010 at 10:07pm |
Use blue coat, it will seal the leak plus coat the inside of the tank. MACK
Brad MI
Joined: 12 Sep 2009 Location: Arcadia MI Points: 339 |
Posted: 20 Nov 2010 at 10:09pm |
Empty and wash out tank real well to make sure there are no residual gasoline vapors. Clean the area to repair; a little blaster works best. Mix up some epoxy and apply to the area. Look over the interior of the tank too, it may need a tank sealer applied. Sand and paint it while it's off the tractor. DONE!
Edited by Brad MI - 20 Nov 2010 at 10:10pm |
GlenninPA
Joined: 11 Sep 2009 Location: Ashley, PA Points: 5054 |
Posted: 21 Nov 2010 at 9:29am |
I taped up all the holes on a tank with black electrical tape (after cleaning like Brad said) and then used POR 15, like Stan said. After it cured, pulled off the tape and used JB Weld to fill in the pits and smoothed it out, Been 10 yrs, tank still holding like a champ.
