7 grand |
Page 12> |
Author | |||
captaindana ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2573 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Oct 2021 at 9:54am |
OK guys I got a new to me Allis 7000 a1976 model which apparently needs a lot of work to get up to my standards. First question is I have two leaky injectors number one and number two; I’ve ordered new copper sleeves and O rings for those two injectors. Can you tell me what kind of a tool I need to replace the copper sleeves with and where I can find such a tool? As always thanks to all! Dana
Blue Skies and Tail Winds
Dana |
Sponsored Links | |||
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8367 |
Would think Agco should have something - Have heard a Cummins tool is close to redo the copper sleeves- or a Cummins shop can fix them
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24754 |
hmm, should you also replace the other injector parts, while you're at it ?? My luck, fix 1+2 then 3 and 6 would leak....
Lynn Marshall ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2415 |
You have to remove the cylinder head to do that. It's expensive and involved. Wouldn't be surprised if the head is cracked too.
orangereborn ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: NW WI Points: 1494 |
I am not very good with the search system but in the past I have posted the tool spec sheet to install the sleeves. If you can't find it, I can get them to you. Sent spec sheet to those that wanted to have a set made but have never heard if it worked out. Dale
Edited by orangereborn - 09 Oct 2021 at 12:59pm |
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3573 |
“7 grand”. Is that your nickname for your new AC 7000? I still like “Mater” cause of it’s tow truck mirrors. Cars movie, Mater’s quote, “Ain’t no need to watch where I’m going,,, just need to know where I’ve been...”
Congratulations! Hoping your 2900’s head isn’t cracked. Regardless, I know you’ll have it purring to your satisfaction soon. Just for fun... https://m.youtube.com/watch?v=HA6xXNToFas |
Ok how do I know if my heads cracked? Bicent Bandit is what the new decals say to go along with big sisters “Bandit “ and “Bandit II”
Dana |
Lol AC7060IL
Dana |
Next up are 7000 brakes same type as 200’s? I only got one🤷🏻♂️
Dana |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22071 |
Let's just slow down here, Bunky. You say injectors are leaking. Leaking what ??? If you're leaking COOLANT, you have a cylinder head issue and the head has to be removed to replace injectors copper tubes, OR the head is cracked, still have to remove the head. Most of the time when someone says they have "injectors leaking" it is simply a valve cover gasket !!!!!
Thanks Doc. Soon as I get home I will surely examine more closely as I should have done last night!
Dana |
FREEDGUY ![]() Orange Level Access ![]() ![]() Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Just out of curiosity, Is this a cabbed machine? Does it have decent rubber and duals in the rear ?
Yup the one from Kokomo with an aux 3ph fuel tank full front weights duals tinted windows
Dana |
Can you post a pic ?? If you were replying to me, I have no clue as to your machine, other than it "might" have come from Plevna ??
If injectors are leaking at copper seat, they will be clean and dust seal may be gone. If injector is leaking where tip cap screws on or valve cover leaking, it will be oily. MACK
In between flying more than full time…and building another 20x60 addition…are 7000 brakes like XT3 and 200 or? Thanks. Dana
Dana |
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8726 |
Believe Dr Allis when he tells you to check the valve cover for leakage!
Sure glad I listened to him on that subject. A friend of mine who had the same issue, wouldn't listen to me, and pulled the injector. Afterwards, he tightened the valve cover bolts slightly, and ate some crow Darrel |
Alex09(WI) ![]() Orange Level ![]() ![]() Joined: 15 Mar 2012 Location: CECIL WI Points: 1754 |
7000 brakes are disk brakes like late 200
www.awtractor.com
KJCHRIS ![]() Orange Level ![]() ![]() Joined: 21 Dec 2015 Location: WC Iowa Points: 966 |
Dana, as Dr says. Check for what leaks, oil is likely from Valve Cover Gskt, bolts work loose and leak, can tighten them 1 or 2 times then needs gskt. If that's your leak there's a update for the cover bolts it's part #74036974 it was started in early '82. The Valve Cover Gskt is #74008074. I've done 5 - 6 on 100 series over 20 yrs, so far no leaks. IF it's diesel fuel leaking check the return line fittings for leak before pulling injectors.
I use a couple cans of brake cleaner to help dry up area leaking, then run a few hours.
Oh believe me y’all I listen to our Doc! And Mack! And y’all! I’m too busy like I said flying and building ano5er tractor storage building BUT we lifted the side cover off of Bicentennial. Bandit and sure enough it looks and smells like OIL! But my concern is still…she just didn’t sound right…. So we shall see when the time comes I will dive into this project. Thanks so much to all. Dana
Dana |
Previous owner said the injection pump had not over 70 hours on a rebuild. When my rebuilt pumps return they look like new. This one on the Bicentennial Bandit doesn’t look like that so IDK maybe a garage Fix or nothing? Thanks Dana
Dana |
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8736 |
are we going to see a picture of the new tractor.
Where abouts are you putting the new shed.
Building "ANOTHER" storage barn ???
Mikez I’m adding westward When the weather turns cold her and things calm down a bit you’ll have to come up with your dad
Dana |
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12236 |
Does that bother you for some reason? Or is it just confusing?
My comment on "another barn" was aimed at his "growing" wealth of OLD ORANGE ![]() ![]() Kudos to the Captain for using/ sheltering these works of art IMO ![]() ![]() |
DanWi ![]() Orange Level Access ![]() ![]() Joined: 18 Sep 2009 Location: wttn Points: 1940 |
Looks good. Did you get your leaks stopped? what were they?
Page 12> |
