180 Hydraulic problems |
Razor
Topic: 180 Hydraulic problemsPosted: 30 Aug 2021 at 8:26am |
Need help I have a 180 that pumps the hydraulic oil out of the transmission breather on the top of the transmission every time it is filled ? I have changed the oil and filter and it keeps losing the Oil out the breather? When the oil is full the hydraulics work until it loses the oil.
Posted: 30 Aug 2021 at 8:35am |
Shift the Power Director lever into neutral or LOW range and if the problem ceases or is improved, the oil seal behind the Power Director clutch (transmission input shaft) needs replacement.
allisorange
Joined: 27 Mar 2010 Location: perkins, michig Points: 381 |
Posted: 30 Aug 2021 at 6:03pm |
Had that with are 180. needs seal like the Dr. said. J.Carlson
MACK
Posted: 30 Aug 2021 at 9:23pm |
The reason it needs a seal, is because the piston ring seals on PD are worn out and maybe the housing they run in. MACK
Razor
Posted: 31 Aug 2021 at 7:47am |
Where can you get the seals do they still make parts ?
Posted: 31 Aug 2021 at 8:09am |
An AGCO dealership !! Three of 70243226 rings.....one of 70242704 retainer, 70235253 seal, 70235254 gasket, and 70250886 split gasket. There are a few other misc. Orings and gaskets behind the brake latch.
Razor
Posted: 31 Aug 2021 at 1:09pm |
Thanks for all the Help I take it it will be some work taking it apart to replace what's wore out it is a bit of work ?
Posted: 31 Aug 2021 at 1:44pm |
Tractor has to be split in two right where you check your hydraulic oil level.
