Zenith Carburetor
bigbirdww View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigbirdww Quote  Post ReplyReply Direct Link To This Post Topic: Zenith Carburetor
    Posted: 24 Aug 2021 at 4:05pm
Rebuilt carb but fuel continues to leak past rubber tipped needle/ seat into the choke intake. Read on some of the post that a non rubber tipped needles work better. Where can I purchase?
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2021 at 4:12pm
If the needle valve is clean, check float for leakage and float setting. To check needle valve, hook fuel to the top of carb only and lift the float.
DaveSB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveSB Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2021 at 4:37pm
Also, fuel must be clean, any small rust particles in fuel may cause needle to leak.
I’ve seen this on carbs I rebuilt for people and they say they still leak, so I have them bring tractor over, and needle has rust particles on it. Gas tank needed cleaning and possibly an in-line filter.
May not be your problem, but something to check.
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigbirdww Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2021 at 8:09pm
Looks like I'll be taking it apart again. Brand new float. I'll try your suggestion. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigbirdww Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2021 at 8:13pm
I did empty out the fuel tank and put in some engineered fuel and flushed. I'll try the in- line filter too. Thanks
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2021 at 9:19pm
Is seat screwed in tight? Some times a new float will drag the sides of bowl.               MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2021 at 8:22pm
The new Viton needles do a great job in seating. The problem with them is if you have debris in the tank or in the inlet of the Carb  (where the elbow screws in)  that debris will almost always stick to the Viton needle.  Remove the 90 degree elbow from the Carburetor and run a bore brush on a hand drill in and out of that cavity to get all the rust and debris out. Make it shine in there.   That is a BIG problem child right there!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigbirdww Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2021 at 11:47am
Awesome. Glad I asked on the forum. A good saturday project is ahead of me.  Thanks
This page was generated in 0.131 seconds.
