fuel gauge float |
D17 owner
Joined: 03 Jul 2010 Location: ladysmith Wi Points: 225 |
Topic: fuel gauge floatPosted: 16 Nov 2010 at 9:23pm |
I need a float for a D17 fuel gauge . I rebuilt all the linkage but cant find a float that would work. I see you can buy the whole gauge after I rebuilt it. I was thinking going down to the Eau Claire peterbuilt to see if I can get one there. Any help would be great. Thanks, Eric
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 16 Nov 2010 at 9:26pm |
Someone posted a while back that a model A Ford gas tank float was the same or close enough to work.
ChuckLuedtkeSEWI
Joined: 11 Sep 2009 Location: Jackson, WI Points: 1826 |
Posted: 16 Nov 2010 at 9:28pm |
Here is a link to a post on a carb float from Oreillys. I picked one up but never got it together to finish it.
D17 owner
Posted: 16 Nov 2010 at 9:45pm |
Thanks guys! I will have to look into them.
ChuckLuedtkeSEWI
Posted: 16 Nov 2010 at 9:53pm |
I do have to say that the oreilly float is a weird looking thing, but it has a metal piece on it, that I think the rod will slide right through, and it's a carb float that's made out of plastic, so I think it should last indefinately. I had the oreillys guys looking for about 45 minutes for it. They finally gave up and took my number down and called me about 20 minutes after I left and said they found it. If I were you, I would make them find it first before you go there, as it's some oddball part and they had it hiding somewhere in a weird inventory section.
Gerald J.
Posted: 16 Nov 2010 at 11:43pm |
Its not necessarily orignal but my tractors are using cork floats coated with sealall. Large corks can often be bought in good hardware stores. And Sealall keeps gasoline as well as alchohols out of the cork.
Gerald J. |
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24763 |
Posted: 17 Nov 2010 at 6:50am |
I cut the float from a Cavalier pump/float unit in half and now both my D-14 gas gages work again!
As long as the 'correct cops' don't stick their heads in the tanks,everythings fine...lol
BobHnwO
Joined: 16 Sep 2009 Location: Jenera Ohio Points: 693 |
Posted: 17 Nov 2010 at 7:12am |
I used a Model A Ford float.
Max(ia)
Joined: 15 Sep 2009 Location: Polk County,Ia Points: 536 |
Posted: 17 Nov 2010 at 8:47am |
Like Gerald J, used a cork from a Hobby Store, sealed with sealall, 3 yrs working so far...
CTuckerNWIL
Posted: 17 Nov 2010 at 9:56am |
Old Standard Auto Parts has the neoprene float for $4. Call Kevin at 866-654-2855 and ask for an A-9313-C gas tank float.
Edited by CTuckerNWIL - 18 Mar 2011 at 9:40am |
Brian Jasper co. Ia
Posted: 17 Nov 2010 at 9:59am |
Where can Seal All be found? Parts store? I have a really nice original fuel gauge with a cork float that the shellac is coming off. Might be just as easy to recoat it instead of trying to get the kids at O'Really Stupids to find something. |
CTuckerNWIL
Posted: 17 Nov 2010 at 10:20am |
Brian, Just call Kevin at 866-654-2855 and ask for an A-9313-C gas tank float. It's $4 plus the ride.
Edited by CTuckerNWIL - 17 Nov 2010 at 10:21am |
Brian Jasper co. Ia
Posted: 17 Nov 2010 at 10:23am |
Yeah, I saw your post. I'm thinking that's probably the best way to go. Looks like it's made of something entirely different from cork. |
Gerald J.
Posted: 17 Nov 2010 at 12:17pm |
I've bought SealAll at True-Value and Ace hardware stores, and at Wallyworld. Usually in the paint/adhesives section of the hardware store and the automotive department at Wallyworld. Should also be in auto parts stores but I've not looked there.
Gerald J. |
John D
Joined: 12 Sep 2009 Location: Sherman, IL Points: 360 |
Posted: 17 Nov 2010 at 12:38pm |
Thanks for the scoop guys! I bought the seal all this morning at O'Reillys ($3.77) and then I saw Charlies idea and called Old Standard. They have it in stock so I now have one headed my way.
NICKMI
Joined: 15 Sep 2009 Location: Greenville Points: 534 |
Posted: 17 Nov 2010 at 1:38pm |
I used a old wine bottle cork woked good
Ryan Renko
Joined: 12 Sep 2009 Location: Edwardsville, I Points: 2336 |
Posted: 17 Nov 2010 at 7:08pm |
I know by experiance and agree 100% with CTucker!!! I ordered the float for only $4.00 plus shipping from his link and it was a simple slip it on and put it back in!!! I'm talking about the float. His link has the float you want!! Just like original. Ryan
cheapjerseys520
Posted: 17 Mar 2011 at 9:06pm |
He has those lined up in his Wholesale Chanel Jewelry new deal as well You spot any team two touchdowns you are not going to Wholesale Cartier Jewelry win It all means that lots of new authentic NFL jerseys will need to be purchased, Wholesale Jewelry and Links of London NFL team merchandise sales will continue at a very rapid paceWe spoke with Colin Crasto, head chef at Dabbawalla, who explained Wholesale Edhardy Jewelry more about their healthy and delicious menu, and how the community has supported them since their opening If there is any team in the NFL that could be considered perfect, this team would fit the bill Wholesale Juicy Jewelry Detroit entered the Wholesale Fashion Costume Jewelry game with only five defensive linemen and three of their starters were out I have included a single lift to take your strength training workout routine to all new heights Eli Manning was having his best game in a couple of monthsThe good Wholesale Links Bracelets thing for all teams and their fans is that this is just week one, and as far as I Wholesale Tiffany Bracelets know, no one is eliminated from the playoffs, except Cleveland, (at least you have LeBron, Opps The Cowboys had a new coach Wholesale Links Necklaces Green Bay ranks second Wholesale D&g Jewelry in Wholesale Swarovski Jewelry the league at 7I Wholesale Lv Jewelry always Wholesale Nfl Jewelry avoid any youth football program run Cheap Wholesale Jewelry by Wholesale Gucci Jewelry someone like this He'll be splitting carries with Ahmad Bradshaw, Wholesale Pandora Jewelry who is eager to make his mark and potentially earn the starting nod Wholesale Bvlgari Jewelry The Patriots did what they often do it's all Links of London Jewelry right there The Eagles 4th quarter comeback was unbelievable"Long term customers Jennifer and Claudio say they love the food Wholesale Hermes Jewelry and come oftencom to find out The Steelers have not always experienced this type of success though as there was an extended period of subpar play that began Pandora Jewelry Coupons when they first took the field Cheap Wholesale Fashion Jewelry as the Pittsburgh Pirates in 1933, and extended up Discount Pandora Jewelry until the 1970sPittsburgh's five-game losing streak last season was the longest slide for a reigning Super Bowl winner since Wholesale Dior Jewelry the 1987 Giants It was human nature for them to be flat Wholesale Links Jewelry All I heard was "Tressel is a horrible play caller," or "Pryor wasn't in a position to rush enough Now evoking conspiracy theorists that Wholesale Vivien Jewelry he scaled down the Wholesale Coach Jewelry offense so that he could get former Wholesale Tiffany Jewelry coach Wade Phillips firedAnother big name on the move is going to be LaDainian Tomlinson Cheap Wholesale Tiffany Jewelry |
MNLonnie
Joined: 11 Sep 2009 Location: Baxter MN Points: 4791 |
Posted: 17 Mar 2011 at 9:09pm |
reported
CORY
Posted: 18 Mar 2011 at 5:54am |
Where can you find the new gauges? I am needing a couple and haven't been able to find any. Thanks for the help.
