ID |
D19allisowner
Topic: IDPosted: 15 Aug 2021 at 10:21am |
Anyone know what engine this is. I was told it could possibly be a Kohler. All I know is it's pretty old.Edited by D19allisowner - 15 Aug 2021 at 10:23am |
If you choose not to decide you still have made a choice.
thendrix
Joined: 04 Feb 2013 Location: Fairmount GA Points: 5106 |
Posted: 15 Aug 2021 at 10:31am |
Not sure but if you try searching the casting number right above the flywheel it might get you started
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34295 |
Posted: 15 Aug 2021 at 12:52pm |
My vote is Tecumseh
Tin shrouding is all gone so will run hot until cooks. Basing on gas tank and flywheel. |
Joined: 11 Sep 2009 Location: illinois Points: 88438 |
Posted: 15 Aug 2021 at 1:19pm |
cylinder bolts to the crank case block... That is not common on most... Should tell you something.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3941 |
Posted: 15 Aug 2021 at 6:16pm |
its a wisconson probley ah model
HudCo
Posted: 15 Aug 2021 at 6:19pm |
lets see the rest of the tractor
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54383 |
Posted: 15 Aug 2021 at 6:30pm |
Ditto! Sometimes if you ID the machine, you can figger out what motor it is!
D19allisowner
Posted: 16 Aug 2021 at 4:22am |
It's a home built machine that friend of mine has so seeing the rest of it's not going to do you any good.
Tad Wicks
Joined: 27 Mar 2011 Location: Shandon, CA Points: 2175 |
Posted: 16 Aug 2021 at 10:01am |
It is a Wisconsin, the air cooling shroud is gone and that is where the data plate is. Almost indestructible, as proven this has been run with no cooling, they can take almost anything but no oil.
Edited by Tad Wicks - 16 Aug 2021 at 10:13am |
